O-ring Part # for Axle Shaft Seal
Hello,
This thread: https://www.ford-trucks.com/forums/9...-bearings.html
Has a part number for an axle shaft o-ring, but for the excursion.
Anyone have that same part number for my 1991 F350 with Sterling full float axle?
Thanks,
David
Thanks,
David
1991 FORD F-350 Axle Shaft Seal
not sure what exactly you need but take a look through the list here closest I've found
If you have the o-ring that came out of it I would do like shorerider said and take it into your local auto shop to see if they can match it otherwise if you're in the rural areas a tractor or farm supply store usually has a great selection of O-rings. If you don't have the original you could use a pair of calipers if you have them to measure the inside and outside diameters of the groove it sets in and take those measurements to the store.
KC8QVO
1999 to 2016 Super Duty
08-09-2018 02:06 PM
FordTrucksKickGM
11-20-2008 07:39 PM
fatdaddy
05-12-2002 10:03 PM
