Sponsored by: Real Truck
HELP - 2005+ MY front 4wd axle shaft spline diameter?
Old Aug 8, 2018 | 03:45 PM
KC8QVO's Avatar
KC8QVO
If I am looking at the dimensions right - the spline is 1.5" in diameter with 35 splines. I just want to triple check... I am making tool OTC6697 and looking at how it is used I was thinking that the inner shoulder (where it goes from 2" ID to 1.75" ID) was to bottom out on the end of the axle shaft. That can't be the case, though, because the spline being 1.5" OD will fit well inside the 1.75" ID of the inner portion of the tool...
So the next question is what stops the tool when pressing the seal on the end of the axle shaft before the axle shaft is inserted in to the axle housing/knuckle assembly? The outer flange of the tool stops the seal at the correct depth inside the knuckle but as far as I can figure up there is nothing to stop the tool against the axle shaft when seating the seal prior to the axle shaft/seal combo going in to the axle housing/knuckle...
Old Aug 8, 2018 | 11:21 PM
KC8QVO's Avatar
KC8QVO
Bump to refresh...
Old Aug 9, 2018 | 06:50 AM
KC8QVO's Avatar
KC8QVO
Bump again to refresh - I need to finish my tool today and get the truck torn down.
Old Aug 9, 2018 | 10:49 AM
ifrythings's Avatar
ifrythings
The Seal bottoms out when you press it onto the axle shaft, there’s no stop for that but there is one for the knuckle as you already stated
Old Aug 9, 2018 | 02:06 PM
KC8QVO's Avatar
KC8QVO
OK. Thanks.
jebee758
Ford Truck Parts for Sale
Jun 17, 2015 08:51 AM
oldcurmudgeon
61
Feb 4, 2014 12:25 PM
mizzitch
Oct 2, 2009 09:01 AM
77f2504by4
May 18, 2008 12:18 PM
