ALRIGHT BOYS NEED ADVICE
Ok I have a 1993 F150 4x4 5.0 5 speed, ok this is what i want it to do to it
1. I6 swap
2. 8 lug conversion with a straight d60 front axel
3. Diamond Plate front and rear bumpers
4. Rhino Line the Frame, Floor boards and Bed
5. Keep the 2 inch body lift and put a 4 inch suspension lift on it
6. With the 4in lift i want to put atleast 37's on it TSL Boggers.
OK HERES THE DILIMA
Me and my dad just pulled off a big job, where hes getting a 1999 f250 power stroke and we're are making 3000 on top of it, my dad said i can either give my truck to my brother (after we are done) i can spend 2000 on another truck or my brother can take the 2000 and buy a truck, what do i do? Do I try to find a truck close to what I want for 2000 and give my truck to my brother or do i let him have the 2000 help guys
1. I6 swap
OK HERES THE DILIMA
Your brother gets a truck for doing nothing? Need another brother?lol. You're going to spend a lot more than $2000 for the parts you plan on putting on the one you have. If you are patient and get lucky, you might come across some good deals. I say forget the I6. Nothing wrong with the 5.0 EFI. If all you're running is 37's, you might be able to use the Dana 44 instead of the more expensive Dana 60. I do think you should upgrade on the rear to the 10.25 because they can be found for next to nothing.
For a tow rig, keep it as close to stock size as possible, especially where you plan on hauling a gooseneck with it. Goosenecks are designed to sit level when hooked to your truck, and it throws the balance off when they aren't. A lift makes it much harder to keep the trailer level.
To make it work on the cheap, find an early superduty (99-03) D50 front axle. They're leaf sprung, and you can redrill the hubs & rotors for the 8 on 6.5" bolt pattern pretty easy. They're easy to locate, and the D50's are relatively cheap.
I don't know if you've ever driven Boggers on the street, but they're not any fun. You can literally see the tread wearing driving them 20 miles on the highway. Pavement driving them, they are 10-12K mile tires, if you're lucky. Don't get me wrong, I LOVE my Boggers in the mud, but they're on my mud toy for a reason.
73f250highboy
483
02-01-2016 04:06 PM
Melendez7.3
01-05-2015 07:13 PM
jesselee20040
07-12-2013 09:11 PM
