i have tried everything, i cant any fuel to enjectors, i have a f250 1992 (chipped ) ford, i have been working on it for 2 days, i have called severl mechanics, they are also puzzled, could anyone else give me any more ideas, thanks
is this gas or diesel???? if diesel check Injection Pump, fuel pump
Gas try fuel Pump
for both check any obstruction in the lines, fuel lines could have collapsed.
iv tried everything on fuel pump, its not collaslp, no power to fuel pump with the key, its not fuses, not relay switch, i have called several mechanics, no one has a clue, if i go direct power to fuel pump it works and shots fuel every where, it was working fine on thursday, then friday it wouldnt start at all, i know it has to be something simple cause iv tried everything else!
Check grounds. Drop the fuel tank and check the connections going to the pump in the tank, Chased one for several weeks, and finally found a spade connector on the pump loose, had to pull the pump to find it
