Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
help
Old Sep 4, 2010 | 03:10 PM
donfbrowninidaho's Avatar
donfbrowninidaho
help
i have tried everything, i cant any fuel to enjectors, i have a f250 1992 (chipped ) ford, i have been working on it for 2 days, i have called severl mechanics, they are also puzzled, could anyone else give me any more ideas, thanks
Old Sep 4, 2010 | 04:14 PM
1969furd's Avatar
1969furd
is this gas or diesel???? if diesel check Injection Pump, fuel pump
Gas try fuel Pump
for both check any obstruction in the lines, fuel lines could have collapsed.
Old Sep 5, 2010 | 10:52 AM
donfbrowninidaho
iv tried everything on fuel pump, its not collaslp, no power to fuel pump with the key, its not fuses, not relay switch, i have called several mechanics, no one has a clue, if i go direct power to fuel pump it works and shots fuel every where, it was working fine on thursday, then friday it wouldnt start at all, i know it has to be something simple cause iv tried everything else!
Old Sep 5, 2010 | 04:58 PM
1969furd's Avatar
1969furd
i would then check the connections and the condition of the wiring to the fuel pump
Old Sep 6, 2010 | 08:48 PM
okc painter's Avatar
okc painter
Check grounds. Drop the fuel tank and check the connections going to the pump in the tank, Chased one for several weeks, and finally found a spade connector on the pump loose, had to pull the pump to find it
nitemandick
Nite, Nascar & Other Limited Edition Ford Trucks
37
Dec 14, 2015 05:38 PM
lemasters f100
19
Feb 19, 2014 08:44 PM
Dunnrightmobile
35
Mar 3, 2012 07:46 AM
Vampiro
103
Apr 24, 2004 10:57 PM
Brad Deicke
Aug 21, 2002 05:08 PM
