rear 2 speed ratio please
The 48 f-6 didn't come home with me. I am looking at I believe a 57 now. I would like to know what the two speed ratio is if possible.
The numbers are as follow from the plate as best as I can tell.
Serial -f70z6h79788
Production code: 07M5527812
rear axle: 650-904
Trans: 5d1r
Thanks
Dave
Serial -f70z6h79788
rear axle: 650-904
Trans: 5d1r
Thanks
Dave
VIN: F70Z6H79788
rear axle: 650-904
Trans: 5DIR
VIN: F70Z6H79788
rear axle: 650-904
Trans: 5DIR
1948/56: Ford stamped the actual ratio(s) on the Rating Plate. 1957 and later use AXLE codes.
Eaton Model 13600 Two Speed Rear Axle / 6.50/9.04-1 / 15,000 lb. Rear Axle Capacity.
Trans 5DIR = Clark 5 Speed Direct.
VIN (Vehicle Identification Number): F70 = F700 / Z = 272 2V H/D / 6 = 1956 / H = Detroit Truck Assembly Plant / 79788 = Numerical Sequence of Assembly = this F700's specific serial number.
davran
12-06-2015 12:07 AM
djshoser
02-02-2005 09:19 AM
