Fuel Tank Padding
Fuel Tank Padding
1996 F350 with 351 and dual steel tanks.
i'm sandblasting my rear frame. removed bed, fuel tanks, exhaust, shocks, etc.
on crossmembers and fuel tank straps, there is a padded material from the factory that is glued on in order to prevent metal to metal contact against the fuel tanks. i had to remove it in order to properly sandblast everything.
what have others used for this purpose when replacing this stuff?
2nd on the camper seal foam tape..
Only been 3 years but it seems to be holding up ok.
I used weather stripping from the hardware store. It was a closed cell foam almost rubber like product. I think it was designed for use when adding a cap on the truck bed. It had an adhesive on one side. Worked pretty good when I replaced the rear tank last fall on '92 F350.
oubesto
Escape & Escape Hybrid
08-19-2016 11:24 AM
Pjames
02-27-2016 11:33 AM
49fordv8f4
01-02-2016 06:10 PM
OFLM
08-20-2014 12:46 PM
1978f-250
03-25-2013 01:56 PM
