6.2L V8 Discuss the 6.2L V8
35/12.50/20 vs 295/70/18
Old 08-13-2017, 10:42 PM
RainDesert's Avatar
RainDesert
RainDesert is offline
I've been running Yoko G015's in 35/12.50/20 since last fall for the snowflake rating. I really prefer the 295/70/18 size and weight rating. The weight savings of dropping down will be roughly 10-12 lbs per tire/wheel vs my existing setup, depending on the tire. Does anyone think I will notice any real difference in performance or mpg if I make the swap?
Old 08-13-2017, 11:06 PM
rspeters's Avatar
rspeters
rspeters is offline
Maybe a little, but not a whole lot. I just went kind of the other direction, from 275/65r20 (34.1x10.8) to 295/65r20 (35.1x11.6) and didn't see enough of a difference to really make it be worth it to switch back to the smaller size.
The 295/65r20 size is one you might consider...it's a hair taller than 35/12.50x20 but if I remember right, it was actually a bit lighter (because it's not as wide).
Going to the 295/70r18 size will affect how it fills up the wheel wells a bit, as well as the stance from front/back.
Old 08-14-2017, 05:11 AM
Ron94150's Avatar
Ron94150
Ron94150 is offline
I think you will notice it drives better, more than you will any performance gains, especially with your 4.30's. My truck drives great, but I feel the wider 12.50 tire, when then asphalts not great, wanting to track more than the old 285's I had.
Old 08-23-2017, 11:35 PM
RainDesert's Avatar
RainDesert
Well, I shall see. I went ahead and ordered the 295's in Michelin Defenders. I will report back any noticeable difference.
Old 09-17-2017, 09:02 AM
RainDesert's Avatar
RainDesert
After 3 tanks now, I can say I'm up at least 1 mpg with the new Michelin's. I also towed 10k yesterday, and the truck definitely towed better and had more power. I got 9.3 mpg on the hour round trip with my machine which was better too.
Old 09-18-2017, 12:00 PM
River Wild's Avatar
River Wild
River Wild is offline
Nice! That is the tire size I'm going to once I wear out the goodyears...if I can wait that long.
Moundainner
1999 to 2016 Super Duty
15
02-17-2016 10:57 AM
jtruck618
07-27-2015 07:09 AM
IslandBlueV10
11-08-2011 12:19 PM
barthel
10-02-2011 12:05 PM
joebatters
08-20-2008 04:35 PM
Quick Reply: 35/12.50/20 vs 295/70/18
