97 Expy w/ 6" Lift (Check Suspension Light On)
Hi Guys!!
I just bought a nice 97 Expy with a Fabtech 6" lift. The check suspension light is on but it sits level. The previous owner told me that it has air ride on all four corners.
Why would the check suspension light be on if its not leaking? One thing I do notice, might be cause Im just not used to the air ride, but it does feel loose when hitting bumps or grooves in the road. Is that normal of an air ride?
Any info is and will be greatly appreciated. Heres some pics.
I don't think you have a 4 wheel air suspeneion. The Fabtech kit works with the rear air suspension trucks bt not the four wheel air trucks. The front air suspension was relly just air shocks, it still used the torsion bars for springs.
My guess is, you have the rear air suspension and because of the lift, the ride height sensor is out of whack. You should be able to have autozone pull a code for you if a light is on.
Someone else might know the air system better here too, my truck doesn't have it.
Ok. I thought all 4x4 Expys had the airrideon all 4 corners. I noticed the switch is in the off position. So I called the previousowner back and he said he keeps it off to keep the back end up while its not in use. Does this make sense? How is it staying up if its off and should I turn it back on? And if I do, how can I keep the back ed from squatting when its not being used?
When you turn off your truck and the switch is on the rear will sag about an inch or so. Mine does this every time I shut it off and pumps right back up when started and put in gear. another thing it will do or anyway mine does it some times, when put into 4x4 it will raise an inch or more, and 4x4 low it will raise some more. Mine doesn't always do this.
nintey4f150
15971
03-13-2022 10:16 AM
79F150/F600
64
11-25-2015 12:33 AM
JoeG
19
04-13-2010 07:23 AM
