South Carolina Chapter Join Chapter, Leader: SC_Hoaty
1997 F-150 Power window motor removal
Old 08-20-2010, 03:35 PM
1997 F-150's Avatar
1997 F-150
1997 F-150 is offline
Question 1997 F-150 Power window motor removal
I have searched the web, my Haynes manual, the threads on this website,and Im starting to wonder if it would be easier just replacing the whole dang door.
The window motor has twice stopped working for some mysterious reason on the driver side and within the same day started working. I thought maybe a lose connection or bad ground. Recently it rolled down and will not go back up. It only makes a faint clicking noise at motor when pushing the up position on the switch. Pushing the down position on the switch causes a clicking noise at the fuse. The fuse has been replaced and I have wiggled and tightened all connections. I currently have the panel off of the door and cant get to the motor. Any suggestions?
Old 08-20-2010, 03:48 PM
jr32560's Avatar
jr32560
jr32560 is offline
should be a couple if dimples in the metal on the door inner skin
you have to drill em out-very carefully so you can get to the bolts
I used like a 1/2 drill bit and drilled really slow
or at least that's how it is on 94s
Old 08-20-2010, 04:02 PM
1997 F-150's Avatar
1997 F-150
Ok I drilled out the dimples and loosened the bolts but the motor still seems to be attached to something. Its definitely more loose.
Old 08-20-2010, 04:34 PM
jr32560's Avatar
jr32560
jr32560 is offline
3 bolts? after that it should just pull away from the mounting place
unless they have the wires tied up against the door~~
Old 08-20-2010, 05:46 PM
1997 F-150's Avatar
1997 F-150
I actually did get the motor loose but tested it and seems to still be working. Where should I go from here? Im pretty sure its electrical but maybe its the regulator. Any insight?
Old 08-20-2010, 05:50 PM
1997 F-150's Avatar
1997 F-150
And why is there a large Chevy advertisement on this webpage!
Old 08-21-2010, 06:47 AM
1997 F-150's Avatar
1997 F-150
Soo many things to fix and such little time, Knowledge, & money. Im at the point of no return with rebuilt motor & new transmission. Now its time for everything else to be replaced!
Old 08-21-2010, 06:59 AM
jr32560's Avatar
jr32560
jr32560 is offline
my 1990 would lock/freeze up in the full down position at times
never did figure that out
worked fine till someone would run it all the way to the lowest down position
and I hit a few bumps -would try beating the crap out of the door e.t.c
would have to remove or loosen the motor then hit the switch
reattach and be good for the next time
finally switched out the entire door-both of em
no rust in them
Old 10-01-2010, 06:52 PM
monckywrench's Avatar
monckywrench
monckywrench is offline
From what I read there is a power window relay that might be malfunctioning.
I test relays by removing them, prying off the cover, then reinstalling them and watching to see if they actuate. I can also close the relay by pressing with a piece of plastic.
Answers.com - Where is the power window relay on a 2001 Ford F150 XLT
poppop50
1999 to 2016 Super Duty
01-07-2021 09:14 PM
KnightIRD
1997 - 2003 F150
09-03-2015 07:21 PM
6 or 10
08-24-2015 08:02 PM
mrjimbov
Electrical Systems/Wiring
11-23-2014 07:20 AM
kyledallas
19
01-03-2012 04:42 PM
Quick Reply: 1997 F-150 Power window motor removal
