03 F150 King Ranch SuperCrew Antenna Base
From a post on another site-------
#3 (permalink) 07-21-10, 04:26 AM
Mike.B
Member Join Date: Jan 2006
Try removing front wheel, then inner splash shield first, even if just enough in that area, to allow reaching inside to access .
#4 (permalink) 07-21-10, 05:18 AM
XSleeper
Member Join Date: Dec 2004
Removing the inner fenderwell allows access to remove the cable from the antenna. The other steps (from above) are to use a small wrench to remove the antenna mast. Cover the perimeter of the fender around the antenna trim cap with a rag and/or tape then pry the trim cap up. Remove the 3 retaining screws that secure the base to the fender.
Mike.B
XSleeper
Now that I look at it again, you probably only need to do this step. And replace the word "remove" with (tighten!)
"The other steps (from above) are to use a small wrench to remove the antenna mast. Cover the perimeter of the fender around the antenna trim cap with a rag and/or tape then pry the trim cap up. Remove the 3 retaining screws that secure the base to the fender. "
2006FOMOCO
10-15-2023 06:12 PM
