New F250 Owner
...death wobble? S'plain that one to me, you mean the steering?
KSCRUDE's assesment that Ford is also plagued with it is not welcomed news, but so far so good. I'll just check my peace of mind at the door for a few months until I'm sure my truck does not have this problem.
The SD's are plauged with this problem as well and are not just tied to the 05-07 trucks although it is more prone on the front coil spring suspension and can even happen to the newer trucks. Some don't have a problem while others do.
If you plan to keep your truck stock, consider swapping out the shocks with quality gas units as well as the steering stabilizer, this will help keep it at bay. Keep the truck well aligned, tires rotated and balanced and keep an eye out on ball joint wear. Mine did the DW at about 55k.
Remember most HD trucks can and do have this problem. It is typically linked to the steering geometry. There are typically absolute fixes for it so don't worry too much about it im sure you will get to love the SD much more than your dodge.
Garryche
05-03-2011 10:22 PM
pinkpanther
03-28-2006 07:20 PM
