1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Superduty bed swap pictorial
Old 08-13-2010, 10:22 AM
BioBurner's Avatar
BioBurner
BioBurner is offline
Here's the problem:
I picked up my 02 F350 for just pennies a couple of years ago because it had been in an accident. I was tipped over on it's side in the snow. I've allready changed out the brush-guard, front fender, bumper, and the front door. I just got a really good deal on this used bed ($500, delivered to my house):
So what follows are pics and an expaination of what was involved in swapping the boxes.
First things, I got under the truck with a can of WD40 and soaked down all 8 of the bolts (Just a note, the bed on the truck has 8 bolts, but the tan one only has holes for 6. I'm going to drill holes for the other 2):
Next thing I did was dissconnect the fuel filler neck from the bed. There are only 3 screws holding in place. I removed them, then I crawled under the truck and muscled the filler neck out of the hole, and secured it out of the way:
Since the nuts on the bottom of the frame rails are retained by little clips, you dont have to have a wrench on the bottom backing you up, so I got out my trusty old T50 Torx socket and went to work loosening the bolts. Or that's how it should have gone. What really happened is the first bolt came right out, then I broke the socket on the next one:
So off to Autozone to exchange the socket for a new one. It broke. So back to Autozone to exchange it for another new one. Then to Sears to buy a Craftsman socket. It broke. So I said "Screwit! I'm getting out the grinder!" and I cut of the remaining 7 bolts:
Next step was to dissconnect the wiring (sorry no picture), there are just 2 connectors behind the driver's side frame rail. After those were free, it was time to round up a couple of friends to help lift. These beds are surprisingly light. Just the 3 of us moved it with minimal effort:
By the way, what does that XTR sticker mean anyway?
Now it was time to remove the stubborn bolts and rusted retainer clips using copious amounts of WD40 and brute force:
The ones that didn't want to come off with mere brute force and copious amounts of WD40 were chopped up. Here's the pile of offending hardware when I finished:
By this time, it was starting to get dark out, and I couldn't really do anything else, as my buddies had gone home and the Ford parts department was closed, so I couln't buy the new fasteners, so I called it a night. I'm thinking I'm going to perform a snorkellectomy before I install the new bed, seing as it's sitting there in the open and all.
Tune in shortly for the next chapter!
Old 08-13-2010, 10:42 AM
sammy77's Avatar
sammy77
sammy77 is offline
I just went thru the same thing on my 05. Had to cut every single bolt off as well. Now would be a good time to paint frame rails as I did. Great write up!!
Old 08-13-2010, 11:10 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
What do you have planned for that cab corner?
Old 08-13-2010, 11:44 AM
BioBurner's Avatar
BioBurner
I was thinking of doing that too. What coating did you use?
I've got a stud welder ordered. I'm going to pull it out myself. Thankfully the truck went over in deep snow, so the door frame is still in pretty good condition, so I think that pulling the dent is all I'm going to need to do (meaning that the door still seals up allright, so I'm not planning on cutting and welding in a new cab corner).
Old 08-13-2010, 11:45 AM
Trucky2's Avatar
Trucky2
Trucky2 is offline
Now that's a unique way to get to the fuel tank to do those in-tank mods.
Old 08-13-2010, 11:49 AM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
Nice how to! Looking forward to seeing it done. Are you going to bond it or spot/plug weld?
Old 08-13-2010, 11:50 AM
Might want to check into wiggle wire. Those cab corners are very tight, and may not work as well as a good ol' slide hammer, but wiggle wire works very well too.
Old 08-13-2010, 12:21 PM
cartmanea's Avatar
cartmanea
Be sure and do the fuel tank harpoon mod while the bed is off!
Old 08-13-2010, 12:32 PM
sammy77's Avatar
sammy77
sammy77 is offline
I used POR-15. I hope it lasts a long time...
Old 08-13-2010, 12:33 PM
sammy77's Avatar
sammy77
sammy77 is offline
Hey where you been??
Old 08-13-2010, 01:20 PM
BioBurner's Avatar
BioBurner
I'm a complete greenhorn when it comes to bodywork. I can do anything mechanical, but bodywork is still a mystery to me. What's the difference here?
What's a "wiggle wire"?
Old 08-13-2010, 01:38 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,101 Likes on 1,001 Posts
One more hint....WD40 is NOT a penetrating oil, it's a water dispersant. Use something like PB Blaster and start soaking the bolts about 2 days before you wanna remove them. Might save you some $. Spray often and heavy.
Nice write-up!!!
Old 08-13-2010, 01:47 PM
cartmanea's Avatar
cartmanea
I used EXCELLENT penetrating oil on my bed bolts and still broke several bits. The stuff I used is Aerokroil, best I've found. I think the bolts are stainless and so they gall on installation so there isn't much you can do to prevent it except apply never seize on assembly.
Old 08-13-2010, 01:54 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
XTR sticker is new to me. Maybe a local dealer add-on?
Nice thread. Reps to you.
Old 08-13-2010, 02:03 PM
dkf's Avatar
dkf
dkf is offline
Looks like you had the same experience I had. The grinder took care of it though. I used PB Blaster soaking them 4 times over 2 days and still no go.
Mine were steel bolts with some type of heavy plating or thin galvanizing on them. The threads were shaped to form threads in the captive nut. The parts counter guy told me the nuts do not come threaded, the bolts form the threads.
Way to go Ford for the **** poor over priced nuts and bolts. The guy who designed that setup must have done so after a nooner on friday.
Quick Reply: Superduty bed swap pictorial
