Have you drained your compressor today?
#47
We folk in the desert southwest need to pay attention to this thread. I drained mine this morning and decanted almost a quart of condensate.
Since the wife installed a temp/humidity/clock on the back porch, I've noted a difference in our local (backyard) humidity and the one at the wide open spaces of the airport.
This must be what's filling my tank. Thanks guys.
humidified, himmelberg
#48
#49
#51
#52
What is the procedure? Pull the valve when its pressurized or when its not?
#53
I just crack open my bottom drain valve while the tank is pressurized, if you open it full open you won't get the water out, the water will rush past the water.
Do you have a moisture trap in your system? If you have a good trap it should prevent water getting to your hose until there's enough water built up, then you have to drain your tank and moisture trap. Also, you have a drain leg in your system to help collect moisture?
#54
#55
on
I used to have a auto drain valve on mine but it never seemed to work very long... it would get clogged with rust and crap and stick... after the third or fourth time disassembling it I finally just tossed it and but a ball valve and a section of hose that runs thru the outside wall... when I think of it I open it up a little... I never get more than a 1/2 cup of water out of the tank...
I've got drop legs and drain valves at each drop and the only thing that comes out of them is spiders...
john
john
#56
john
john
#57
#58
john
john
"High Speed" spiders I'd bet
#59
#60
john
john
I think I will have to raise the tank a little, so going to use a hard rubber isolator on the three legs.. (hockey puck, I think)
mine is an 80 gal tank. jacking it up will be fun! (not).. heck. just use my engine hoist!
Sam
