replacing rear brake cylinder
Depending if it has dayton or bud wheels
If they are dayton it's optional if you want to remove the wheels and tires,it is lighter to get off without tires on it
If Budd wheels I don't recall if '79s had outboard drums
If it does have outboard drums remove wheels and tires and slide drum off
If it does not have outboard drums it's the same process as the dayton hubs
Remove axle shafts and remove bearing nuts
Loosen brake adjusters and slide the hub and drum off the spindle
When you remove the nuts on the axle there are cone locks that hold the axle in that can be pretty trying
I always hit the axle in the center with an 8 or 12 pound sledge hammer and it will viberate the cones loose and you can wedge a small screwdriver in the crack and pull it off the stud
Once the drums are off the you can take the lines off of the cylinders, remove the bolts and pull the cylinders out
Biggone
10-12-2014 12:22 PM
