Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Engine smoke, Help!!!
Old Aug 10, 2010 | 11:29 AM
jgprolandscaping's Avatar
jgprolandscaping
Hello, My 79 f600 370 2v 2wd 5speed started blowing smoke out of the exhaust while i was bleeding the brakes, The smoke was really heavy at first and then was just a steady flow of white smoke, I didnt hear any knocking or anything unusual,
This morning I went out and stated it up and let it warm up and there was only a little smoke
The oil and filter has been recently been changed and filter
somone told me it could be the umbrellas over the valves
the truck has 75,000 miles, any help will help me alot
Old Aug 10, 2010 | 01:02 PM
85e150's Avatar
85e150
Fire it up and pump on the brakes a bit. You might be sucking brake fluid via a leaking master and vacuum booster. You should have a hydra-vac under the cab that provides boost for the brakes.
edit: I see you have an answer and know all about the hydra-vac:
https://www.ford-trucks.com/forums/9...-cylinder.html
gbeach
Jan 23, 2015 03:58 PM
TAZ01
Feb 16, 2013 09:19 AM
Jasonszion
Jul 30, 2011 11:16 AM
ajstumpf
1978 - 1996 Big Bronco
Oct 26, 2003 07:51 PM
