Aftermarket rotors for a 2005 2WD F150?
My humble farm truck with 36,000 has warped rotors from hauling stuff and still has about 2/3rds life left in the stock front brake pads. I'm looking for an aftermarket set of rotors that won't warp under "normal" hauling loads. I don't need the brakes to work better, since I've got sports cars for going fast, but I would like to purchase a set of front rotors that are superior to the OEM rotors and won't warp because I came to an easy stop while hauling 1500 pounds of paver bricks in the back.
I will, of course replace, the pads with the rotors and repack the wheel bearings. Any and all recommendations will be appreciated.
Thanks!
Eric
Thanks!
Eric
Hubs
This link is for the 6 lug hugs 2004-2008 Centrics part 124.65902. Have to admit they're less expensive than Zeckhausen lists them for.
Update - Found RockAuto also lists them: http://www.rockauto.com/catalog/raframecatalog.php, also lists a pretty good price on them.
Zeckhausen shows them out of stock., while not noted on either of the other 2 sites.
One thing I'm wondering is what bearings you need to use along with will any general 04-08 4x4 brake rotor work? Mine happens to be a 7 lug hub so I'm thinking of getting them early, every time I wait on odd-ball size items, they're discontinued when I need them.
Paul
KJNDIVER
37
08-19-2020 11:24 PM
XCUR&F350
1999 to 2016 Super Duty
06-22-2017 08:14 AM
