Major problems....NEED HELP
Hey everyone,
Okay, first off let me say I have a 2006 F350 6.0 with 170,000 miles. Just bought it a few weeks ago so I don't know the history. The first couple of weeks I had it it ran fine, was a dog out of the hole but I figured it needed a good turbo cleaning. It has never black smoked while driving it that I have noticed. About 2 weeks after I got it I noticed some white smoke coming out of the exhaust when I first pulled out of the driveway. It would do it for about 3-4 seconds and then stop and never do it again. 2 days ago it started to black smoke quite a bit when taking off from a dead stop, both under light acceleration and under heavier acceleration, didn't matter. Obviously it would smoke a little more under heavier acceleration though. I drove it last night with no issues other than the black smoke. Late this morning I started it up and was going to let it warm up a few minutes before I took off (as I always do) and as I was sitting in it I noticed a lot of white smoke while it was idling. I push on the throttle a little bit and a lot more white smoke came out and it was running very rough. I put it in gear and it wouldn't even move. White smoke and just jerking quite a bit. Turned it off and came inside to post this. What do you guys think.....hopefully not head gaskets....can't afford that yet.
thanks
thanks
It's out of warranty. I have been doing to research to replace this over the past week or so. Was planning on doing a cooler delete, new oil cooler, turbo clean, etc. Was also going to clean the EGR and intake of soot. I need some help on part numbers now for the following.
Turbo oil drain
Turbo oil feed
HPOP filter
Coolant filter
I know some of these items have had updated part numbers. Anything else I should update or change while I'm in there?
Turbo oil drain
Turbo oil feed
HPOP filter
Coolant filter
Turbo oil drain 6C3Z-9T515-A
Turbo oil feed 3C3Z-9T516-A
HPOP filter 3C3Z-6C683-AB
Coolant filter This is an aftermarket part
Engine Oil Cooler: 3C3Z-6A642-CA for the "kit" (3C3Z-6A642-AA for a whole cooler)
STC Fitting Update Kit: 4C3Z-9B246-F
Dummy Rail Plugs: -W302908
Thanks for all the good help you provide here!
