74 ranchero engine help
Old 07-27-2010, 02:24 AM
FordManMT's Avatar
FordManMT
FordManMT is offline
How do you go about turbo charging a carborated 460?
Old 07-27-2010, 01:27 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Manifold set up, blow through carb, oiling set up, heat shielding, intake and filter set up, and a couple of engine rebuilds.
Is this a 460 you are building, or a many miles motor that's in the Ranchero already?
You can make more power with a NA 460 than the stock chassis can handle.
Old 07-27-2010, 03:28 PM
FordManMT's Avatar
FordManMT
I am planning to TIG weld the 8 into 1 exsaust manifold, and run a high power oil pump with a oiling cooler and line to the turbo.
Welding and fabrication isent a problem. Finding the proper turbo and injection system is.
I want to do a bi-turbo set up. Much like the ford 6.4 (I believe, could be the 6.0 I can't recall). So I will have a small turbo spoiling up fast and a larger turbo for higher rpm.
For a fuel system I want to run a carborator, fuel injection is very costly and this is a budget build.
As for the frame, the rear end has a 9in and trailing arms, I plan on keeping the axle and doing eather a triangulated 3 link, or a 4 link suspention. For tranny I have a C6 automatic
Old 07-27-2010, 03:47 PM
85e150's Avatar
85e150
For twin turbos, I don't think you want 8 into 1.
This is supercharger talk, but you'll run into some of the same issues. Other discussions there also:
Supercharger build - 460 Ford Forum
Your topic is turbocharging, not Ranchero, so you may want to post in this forum:
https://www.ford-trucks.com/forums/5...r-vehicle.html
Old 07-27-2010, 05:32 PM
FordManMT's Avatar
FordManMT
Your right. I will still post the build on this. Anyone know where ican get quarter pannels? I can't seem to find any
Old 07-30-2010, 07:38 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by FordManMT
Anyone know where i can get quarter pannels? I can't seem to find any
D2OZ9727846A .. Right Quarter Panel / Obsolete
D2OZ9727847A .. Left Quarter Panel / Obsolete
Fits: 1972/76 Ranchero / No Ford Dealer or obsolete parts vendor has any.
Where is the damage (prolly caused by rust), above the wheel wells and along the bottom of the quarter panels?
Find a 1972/76 Torino 2 door, then cut the quarter panels from it, then splice in the lower section of the 2 door panels to the Ranchero's quarter panels.
Old 07-30-2010, 03:35 PM
FordManMT's Avatar
FordManMT
Thanks man. I am considering cutting a inch or 2 out of the rear quarter pannels to eliminate rust and fit larger tires. Rust in rocker pannels shouldn't be to difficult to replace or patch.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 74 ranchero engine help
