Pinstripe replacement?
Old 07-26-2010, 11:41 AM
smashclash's Avatar
smashclash
smashclash is offline
I'm getting ready to paint a new drivers side door of my truck. Problem is my truck is two tone paint (red top and bottom and white in the middle). Anyway, Ford covers the seams of the contrasting paints at the bottom with a plastic trim (which I can remove from the current door and replace with double stick tape). However, the top portion is masked with a 2 stripe pinstripe. Doing a search on this board you have to either buy an entire kit or go to a sign shop. The one currently on the door I'm replacing is fine but is it possible to remove the pinstripe and reuse it on the new door? I'm worried even with a heat gun/hairdryer that when I go to pull on the pinstripe it will either eventually rip as I'm removing it or will stretch out of shape and be unusable.
Any suggestions?
Old 07-26-2010, 12:10 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
No, You will not be able to reuse it ... Sign shop is your best bet. A few bux if that!
-Enjoy
fh : )_~
Old 08-13-2010, 03:54 PM
Colorado Ford Guy's Avatar
Colorado Ford Guy
Colorado Ford Guy is offline
dennis-carpenter.com has the original ford stripe kits.
FORDF100SB
06-01-2015 12:18 AM
Thunderbird7480
07-07-2011 10:26 PM
IzzyR
Paint & Bodywork
05-05-2008 05:49 PM
Boss50
Paint & Bodywork
08-18-2005 07:01 PM
xTREME HAULER
Paint & Bodywork
04-17-2005 04:38 PM
Quick Reply: Pinstripe replacement?
