well if you guys have read my other threads then you know what is goin on. my truck keeps shuttin down when i hit the brakes and misses when it is facin down hill or hitting bumps. i checked my oil and it is bout 2-4 quarts low. could that cause these symptoms?
thats what im gonna do cause my dad said before that he had a problem with it shuttin down on him going around right turns but would start right back up and ford said it was low. figured save me a big bill from the stealership anyways. but i wanted your opinions cause i never knew that low oil may cause a real rough idle and occasional shut down
Ya, I broke my brass oil pressure line and the motor quit running, it was low on oil. I was told the computer will shut it down if it see's less then 6psi pressure. A great feature to protect our motors!
Mine will miss sometimes if the oil is a little low. So I would think if it was to low and your hpop was a little weak there may not be enough pressure to run the injectors. You may even wanna try changing the oil.
