When EXACTLY did Mustang get roller cam?
Old 07-23-2010, 09:35 AM
xfordman's Avatar
xfordman
xfordman is offline
I heard in 1984 in the 5 speeds only, is that correct and weren't they still carbed then? thanks
Old 07-23-2010, 03:33 PM
Conanski's Avatar
Conanski
Conanski is offline
I know the '86 had one and that was close to if not the first year for it. In '87 the 5.0 block was updated to be roller ready so any 5.0 motor with E7TE or later casting numbers is a roller block that will accept the factory roller assmebly with little or no machineing.
Old 07-23-2010, 04:00 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
I think 1985 was the first year that the 5.0 HO in the Mustang got the roller cam. The block was modified with the taller lifter bores and holes for the hold-down spider for the lifter alignment thingies.
Old 07-23-2010, 04:12 PM
Old Hickory's Avatar
Old Hickory
Old Hickory is offline
The 85 5.0 4V engines were the first to have roller cams. Also available in a Mustang in
85 was a 5.0 with a throttle body that was a flat tappet cam. I bought a new Mustang
in 1985 that had the 5.0 flat tappet because it was available with the AOD trans while
the 4V engine was only available with a 5 speed.
Old 07-24-2010, 07:24 AM
xfordman's Avatar
xfordman
xfordman is offline
AH... so it's 85 with stick shift only, thanks guys
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: When EXACTLY did Mustang get roller cam?
