4R70W compatibility
Old 07-27-2010, 01:41 PM
facelessnumber's Avatar
facelessnumber
facelessnumber is offline
4R70W compatibility
(Kind of related to an old thread, so mods please move or delete this if I'm breaking any rules... I tried asking in my other thread, but my new questions are buried in a long, old discussion so I don't think they are being seen.)
My problem is simply this: I have lost all forward gears in my '97 E150 with a 4R70W. I plan to put a junkyard transmission in it this weekend, (as I did a year and a half and 30k miles ago) and I need to know what's compatible.
My research tells me the following:
                Am I missing anything?
                My possible list of donor vehicles includes:
                      I believe all of these cars have a 4R70W when equipped with a 4.6. Are any of these transmissions not compatible, or for any other reason to be avoided?
                      Armed with the knowledge above and a pin diagram, I should be able to use just about any 4R70W transmission in my van, right?
                      Thanks in advance for any help you can give. Now that I actually own this van, I'm sure I will have more questions. I will probably become a regular around here, and eventually I hope I'll be able to contribute my own experience to the knowledge base the board provides.
                      Old 07-29-2010, 06:26 PM
                      alowfalcon1's Avatar
                      alowfalcon1
                      alowfalcon1 is offline
                      oh man I'm in the same boat. Is the 4r70w the same as the aode? I'm a mustang guy and have connections to the aode trans. will it work in my van with a 4.2?
                      Old 07-29-2010, 08:09 PM
                      facelessnumber
                      4R70W is not quite the same as the AODE, although it is derived from it. The gear ratios aren't the same and they apparently aren't directly interchangeable.
                      Old 08-03-2010, 02:11 PM
                      facelessnumber
                      Ok, well that's all done... For the record, a 4R70W from a '97 Grand Marquis worked just fine.
                      BrettMavriK
                      100
                      01-14-2018 11:08 AM
                      Aaron-71
                      57
                      02-27-2016 10:58 PM
                      KsCop
                      06-30-2014 12:48 AM
                      jarod17
                      Testing.....
                      06-28-2011 10:57 PM
                      71cc
                      03-20-2010 09:14 PM
                      Quick Reply: 4R70W compatibility
