stc fitting installed on a pump.
#46
I'm in the same boat as many here 68k. ZERO issues, but its something thats gotta be done as far as I'm concerend. I will hopefully have this truck for a long time and I'll do what I gotta do to ensure that. Now this being said this isn't the easiest job so if you even think you're gonna tackle it on you're own do PLENTY of research and best of luck...
#47
#48
on
My 2005 has 62,000 trouble free miles except for FICM replacement on warranty. You are saying I should tear it down and replace the STC fitting? Man that is hard to think about tearing into a perfectly running engine to replace something that might not ever give any problems. Not saying it isn't a good idea, is there any statistics on how many STC fittings fail?
#49
#54
Question on removing HPOP
I am in midst of doing a bunch of updates, exhaust, EGR Delete, turbo etc. Decided to do my STC but I'm a nervous wreck. I cleaned it up a bit and took all bolts off of cover, however when I pried it up I heard a tickle of something falling. Now I have no idea where it was or what it was. I will try to look carefully when pump is out and fish with a magnet. How do I get the pump out? I took the three bolt off already, do the two small bolts on STC need to come off? I can't get to right now but could put plastic bag over hole and take up pipe off as it is going to be replaced anyway.
#56
Yes you do need to remove the two bolts that hold the STC fitting on in order to lift the pump. As far as a bag you can use either that or shove either a bunch of rags or paper towls and then just sit the cover back on. For the hole in the top of the cover you could put some very good tape on to cover. Get creative, and just make sure it's closed up until you are ready for re-install.
#57
#58
Thanks! I got it out and do
ing stc now.
ing stc now.
#59
Dang I haven't it over that yet! I did my oil cooler egr cooler had it all back together and then learned about the stc fitting. Soni took it all back apart and installed the new fitting. Just soni would not have to be concerned with it.
