Easy ways to improve 460 horsepower
Old 07-13-2010, 07:41 PM
CanadianBigBlue460's Avatar
CanadianBigBlue460
CanadianBigBlue460 is offline
As of now i have a completely stock 460 engine from air filter to oil pan IN MY 76 f-250. I want to increase the power as much as possible on a slightly low budget. I was wondering what parts are the best to add to the engine to get more horsepower.
Old 07-14-2010, 10:29 AM
hasteranger's Avatar
hasteranger
hasteranger is offline
headers, port the heads, change intake over to an edelbrock air gap or something similar, aftermarket 600-700 cfm carb, and add a more aggressive cam and you will have more power than you know what to do with.
I'd do a compression/leakdown test first to see if what you have is worth building anyway.
But you can do all that with the block still in the truck.
Not a bad idea to add a larger milodin or copy oil pan. More oil= cleaner, cooler oil.
And there are small but measurable gains to be had in upgrading your ignition, whether to a newer style integrated distributor or just with a new cap and upgraded coil and an MSD box.
Old 07-14-2010, 10:46 AM
Blown 331's Avatar
Blown 331
Blown 331 is offline
Straight up timing set is cheap and noticeable power.
Old 07-14-2010, 12:37 PM
704 dentside man's Avatar
704 dentside man
704 dentside man is offline
How cheap is cheap? Because 514 strokers are relatively cheap...under $1500. Alright, now back to reality...a 4bbl setup with a carb in the 650-700 cfm range and I prefer weiand intakes on my 460's, that'll help it inhale and lose about 70#'s. Next I'd consider a cam kit. And finally a set of headers and exhaust. You'll definitely be able to tell a difference and can be done $1500 if you buy all new parts and you do all the work.
Old 07-14-2010, 12:49 PM
marcograms's Avatar
marcograms
marcograms is offline
My 78 460 has an MSD ignition, 750 Edelbrock carb, dual exhaust with straight through mufflers, straight up timing set and RV cam. I don't know the specs of the cam. This truck will absolutely melt the tires from a dead stop with an automatic and pulls great. It wraps the speedo around as well on the top end. Much faster than I think it needs to go. It still gets as good of mileage as my friends new quad cab half ton.
Old 07-14-2010, 01:37 PM
hasteranger
what would be the point of putting a 514 kit in an engine with stock ignition, heads, manifolds, and carb, though? The displacement isn't the limiting factor at that point.
The headers and exhaust will make more power on a factory cam, but aftermarket cams don't make peak power without headers... so I'd do headers before cam.
Old 07-14-2010, 08:41 PM
marcograms's Avatar
marcograms
I'm just curious, as far as torque, would a straight up 514 put out more than a modded 460? Wouldn't it be like a caddy 500 or would the heads limit it? I've always wondered why can't you just build a stroker without all the extras.
Old 07-14-2010, 08:52 PM
hasteranger
i doubt anyone has ever done it, but the stock 460 is choked by the OEM manifolds, both intake and exhaust.....
Old 07-14-2010, 08:57 PM
Blown 331's Avatar
Blown 331
I'm my opinoin a 460 with heads, cam, intake and exhaust would runs circles around a 514 with stock cam, heads, intake and exhaust. And the 460 would cost less and be easier.
Old 07-14-2010, 09:26 PM
marcograms's Avatar
marcograms
That's what I wanted to know. I really like low rpm torque and pulling power. I still have the stock intake and exhaust manifolds. How are these for low rpm power and what is their limit?
Old 07-15-2010, 06:05 AM
miottimouse's Avatar
miottimouse
miottimouse is offline
i run headman headers/2.5" duels edelbrock 600 carb/manifold crane 272 cam stock heads aftermarket hei dist on my sc all the power i need to pull a 10ft camper and 18ft boat on the highway in overdrive at 2000 rpm my reg cab with the 501 scat stroker kit is another story 750 edelbrock carb/airgap intake/heads 9.5 1 pistons,headers.2.5"duels roller rockers 272 cam hei dist 8qt marine oilpan w/ rear pickup all the power i could never use [500hp] it all boils down to how fast do you want to go and how much money do you have to spend
Old 07-15-2010, 08:55 AM
704 dentside man
I didn't figure the guy needed a dissertation on a stroker kit. It was meant more tongue in cheek because I knew what else would entail. But knowing how cheap, cheap is would be helpful. If 5grand is the limit, he could throw together a 514 (but if he has that coin, why not just spend the extra couple hundred from machine work and go 521).
As for cam vs. headers...I agree, I was just throwing out the typically bolt in/ons, not necessarily in any particular order.
Old 07-16-2010, 01:09 PM
masterbeavis's Avatar
masterbeavis
masterbeavis is offline
Why stop at 521? I have heard there are larger kits out there.
Seriously tho I would look at just doing a double roller straight up timing set from a 92-97 or 68ish 460(non retarded), look for the writeup on how to re-curve your distributor, Weiand aluminum intake and a proper camshaft for how your truck is currently set up. There is stuff you can do to your carburetor to help with the power too. Hopefully you have a non autolite carburetor? Lots of options, do your homework and dont get carried away buying stuff that is shiney but wont really do anything for you. Be honest and realistic about what you expect the truck to do and how much you can afford. Other things to consider as well is axle gearing and tire size. If you are pushing 44's with 3.55 gearing, any motor is going to feel like a slug.
How much can you afford to put into this motor?
Old 07-16-2010, 01:15 PM
Blown 331's Avatar
Blown 331
Just wondering if you've had a bad experience with an autolite? I have an autolite 2 barrel on my Fairlane and it does't run all that great. Are they not very good, my brother seems to like them????
The following users liked this post:
Old 07-16-2010, 11:37 PM
masterbeavis
I have only seen one 429/460 with a 2V carburetor, otherwise they all came with either a Quadrajet(rare), Holley 4180, or square/spread bore Autolite 4V carbs. The 2V autolites I will run in a heartbeat, just not the 4V ones. I suppose if you know what you are doing you can make a 4v autolite work, but I stick with what I know.
Quick Reply: Easy ways to improve 460 horsepower
