97' E350 V10 LONG CRANK
Old 07-12-2010, 02:25 PM
BAZOOKA FACE's Avatar
BAZOOKA FACE
BAZOOKA FACE is offline
I have a 97' E350 v10 and on cold start will crank for a very long time before starting. Pressing gas pedal does not help. I'm thinking fuel pump.
Any ideas?
Old 07-14-2010, 10:57 AM
BAZOOKA FACE
Started van today with a fuel pressure gauge hooked up and fuel pressure seems good. Maybe time for plugs?
Old 07-14-2010, 02:48 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
Only on a cold start?
You might want to change/check the coolant temp sensor, it tells the computor the engine is cold and sets the injector pulses accordingly
Hope this helps
Old 07-14-2010, 06:45 PM
BAZOOKA FACE
Yes only cold start. I will try checking that.
Old 07-14-2010, 06:50 PM
BAZOOKA FACE
Also I check one spark plug. It was ok except It was a bosch, which I know Fords do not like. The original owner must have had them installed before I bought the van.
Old 07-16-2010, 04:08 PM
Grems4ever's Avatar
Grems4ever
Grems4ever is offline
I wouldn't sweat the plugs right now.
If you try the coolant temp sensor with no improvement, I'd run a compression test when the engine is cold. This will rule out any mechanical issues. Remember - it needs 4 things to start: fuel, air, spark, and compression to run. A compression test will rule out 2 of the 4 (air & compression).
Keep us informed...
Old 08-08-2010, 05:18 PM
BAZOOKA FACE
Replaced both the crank sensor and the coolant temp sensor. Still has same problem.
Old 08-08-2010, 05:42 PM
'88 E-350's Avatar
'88 E-350
'88 E-350 is offline
My first suspicion would be fuel pressure. I know you did a pressure test, but try cycling the key on-off before trying to fire it. That'll give the pump more time to build up pressure before cranking. You could also try firing it and turning it off right away, then restart. If it starts quickly the second time or after 'priming' the pump it's likely fuel pressure. Could be a leak, regulator, or probably the pump starting to go.
Old 08-08-2010, 05:55 PM
BAZOOKA FACE
The fuel pressure will show 40psi instantly as soon as key turned then stay there while cranking.
Old 08-08-2010, 06:47 PM
Grems4ever's Avatar
Grems4ever
Run that compression test yet?
Old 08-08-2010, 08:42 PM
BAZOOKA FACE
No. I will this week and report back.
Old 08-19-2010, 01:17 PM
BAZOOKA FACE
Compression tested good!
Old 08-19-2010, 03:16 PM
'88 E-350's Avatar
'88 E-350
Have you tried my start and restart test? It may point to a direction. I'd also check that the fuel press. regulator isn't leaking fuel to the vacuum line, would flood the motor when parked.
Old 08-19-2010, 03:18 PM
'88 E-350's Avatar
'88 E-350
also, did this start suddenly or slowly worsen, was there anything done to the truck right before it started? Even something seemingly innocuous could be connected.
Old 08-19-2010, 07:50 PM
Grems4ever's Avatar
Grems4ever
Have you read this thread? Sounds like its very similar to what you are experiencing.
https://www.ford-trucks.com/forums/9...-starting.html
Quick Reply: 97' E350 V10 LONG CRANK
