Right turn clunk
Old 07-01-2010, 12:31 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
Right turn clunk
Hey guys....i've noticed that when i make a right turn and apply throttle i get a bit of a clunk in the driveline....oddly it doesn't do it turning left......anyone have any ideas???
Old 07-01-2010, 01:13 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
Ryan,
I had problems with a "dry" U-joint (and "assembly")causing a similar scenario-in fact its time for me to look at mine again.
The TSBs also mention something similar but that is in the AWD or 4WD mode- and that suggests the front tire pressures being possibly suspect (iirc).
Old 07-01-2010, 02:16 PM
Ryan50hrl's Avatar
Ryan50hrl
Its just in 2wd that i've noticed it...
Old 07-01-2010, 03:06 PM
Bill W's Avatar
Bill W
Bill W is offline
It's something political.
just kidding Ryan
Old 07-01-2010, 03:25 PM
Ryan50hrl's Avatar
Ryan50hrl
Damn it bill.....not at all helpful.... LOL....... So rich...you just replaced the ujoints and the problem went away??
Old 07-01-2010, 03:31 PM
Ryan50hrl's Avatar
Ryan50hrl
And....what brand u-joints is everyone goin with nowadays.....its been years since i've had anything i had to put ujoints in...
Old 07-01-2010, 03:34 PM
CropDusterMan's Avatar
CropDusterMan
CropDusterMan is offline
LOL Bill...now that was funny! We could take that thread for a mile or two...
"And when I turn left...there is this terrible whining noise."
Old 07-01-2010, 03:36 PM
Ryan50hrl's Avatar
Ryan50hrl
I could blame the right for breaking everything it touches.......if i just kept goin left everything would be fine.......LOL
Old 07-01-2010, 03:40 PM
CropDusterMan
See what I mean...? A Mile I tell ya!
Old 07-01-2010, 03:43 PM
Bill W's Avatar
Bill W
Bill W is offline
Sounds like a Ball joint to me.
Old 07-01-2010, 03:47 PM
Bill W's Avatar
Bill W
Bill W is offline
Oh wait... in 2wd?, not a 2 wheel drive... yea, check the u joints
Old 07-01-2010, 03:52 PM
Ryan50hrl's Avatar
Ryan50hrl
yep....its not a ball joint....they're all new....(by the way...if any parts guys tell ya you have to change the whole lower arm.....they're on crack).....the part is listed under a 05....but not an 07.......same lower ball joint....
Old 07-02-2010, 05:03 AM
svt2205's Avatar
svt2205
svt2205 is offline
Ok, the ball joints and sway bar end links are new.
Now is the cluck the same as the sound you had before you changed these? If it's different, then I'd say it's not a problem with one of the new ball joints or end links. If it's the same sort of noise, then check those new parts out. You could have something that came loose or was damaged (there really are lots of forces applied to front suspension components) or you installed defective parts.
Rule that stuff out and move to other possible sources.
Old 07-02-2010, 11:36 AM
Ryan50hrl's Avatar
Ryan50hrl
Nope....entirely new sound....its defenitly not a suspension noise.....its in the driveline somewhere.....
Old 07-04-2010, 07:54 PM
fryar_tuc's Avatar
fryar_tuc
fryar_tuc is offline
I had that noise. My trans crapped out shortly afterwards. i found chunks of metal in my trans filter. it sounded like a back brake dragging at first. It quit...now.
Quick Reply: Right turn clunk
