Is gutting converters bad for my truck?
#46
But mine has a Y-pipe. With a converter on either side.
Doubt it has one on each side, would negate the need for a Y pipe, based on your comments it really sounds like you have never looked at it to see just what is there.
A Y pipe is used to bring both sides to the same point, to one side or the other, with dual exhaust one wouldn't be needed.
Dual cats might be used to save space, two smaller ones used rather then one large one, both installed in the same pipe, one right after the other. One might be a resonator. I'm just not that familiar with the 150ies or the 302's in this generation of truck to say for sure either way.
When the others state you should have two cats, that is very likely how its set up.
#47
#48
#49
#50
Yea you have two cats, do two pipes enter the first one similar to the way mine was? Or is the cat part of the Y pipe itself?
I believe the I6 of this generation uses two exhaust manifolds rather then one large one, 3 cylinders feeding each one and a Y pipe leading into the first cat.
Is yours like that?
#51
Is yours like that?
Is yours like that?
grindit60
12-10-2013 10:59 AM
