2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Rear Strut Replacement
Old 06-20-2010, 08:17 AM
BGreeson's Avatar
BGreeson
BGreeson is offline
I have a 07 Expy EL and need to replace rear struts. Ride is ok but they are make terrible noise when loaded. I had them replaced under warranty but warranty is out now and I am looking for something other than OEM as these have not lasted. I have roll stability control so I am not sure of functionality of RSC on aftermarket. Any ideas? Also any experience on replacing struts? Procedure?
Old 06-21-2010, 01:02 PM
berry1234's Avatar
berry1234
berry1234 is offline
Removal and Installation
CAUTION: Suspension fasteners are critical parts because they affect performance of vital components and systems and their failure may result in major service expense. New parts must be installed with the same part numbers or equivalent part, if replacement is necessary. Do not use a replacement part of lesser quality or substitute design. Torque values must be used as specified during reassembly to make sure correct retention of these parts.
1. Remove the lower arm.
2. Remove and discard the shock absorber upper mount nuts.
o To install, tighten to 40 Nm (30 lb-ft).
3. Remove the shock absorber and spring assembly.
4. NOTE: If the individual spring and/or shock components are not being serviced, continue with Step 7. NOTE: For reference during assembly, index the upper mount, spring and shock absorber. Using a suitable spring compressor, compress the spring until the tension is released from the shock absorber.
5. While holding the shock rod, remove the nut and washer.
o Remove the shock absorber.
o Discard the nut.
o To install, tighten to 56 Nm (41 lb-ft).
6. Remove the upper mount, dust boot and insulator.
7. To install, reverse the removal procedure.
PM me and I can email your the diagrams.
mnm27mnm
2004 - 2008 F150
05-13-2020 09:45 PM
AGrayson84
1997-2006 Expedition & Navigator
10-25-2016 12:14 PM
svfetter
03-18-2016 07:22 AM
mrgriz
11-08-2015 10:21 PM
theoldwizard
10-18-2015 04:06 PM
Quick Reply: Rear Strut Replacement
