6.9 liter performance mods/ upgrades
hey im new to the form and had some questions for yall. I have a 6.9l diesel IDI and i wantde to give her some more ***.
My dad has a 7.3l excursion with a hypertec chip, magnaflow exhaust and a volant air intake. From a dead stop while towing an armored vehical he kills me! no load in the truck and im running offroad diesel.
Help?
dont want a sled truck just something i can have fun with and still do some work.
Any ideas at all ill take
thanks for your time
Kevin St.Amant
Help?
Kevin St.Amant
Welcome to the IDI forum.
The biggest single mod you can do to your 6.9 is to add a turbo. I think ATS is the only active company still offering a kit for the IDI. But, you can find deals on good used kits on Ebay, Craigslist etc.
If you are wanting to stay NA, there are a few things you can do. Free up the exhaust with duals or a larger single system with good muffler, or none if you like more growl.
Get more air into the engine with a ram air setup. Cut out the soup bowl on the air cleaner lid.
You can turn up the fuel a flat or two. But you need to install a pyrometer before you do to monitor the exhaust temp. Pretty easy to melt pistons.
Jason
Jason
Jason
Jason
on
dont expect an n/a idi to keep up with a 7.3l powerstroke.it wont.
dont expect a turbocharged idi to keep up with 7.3l with a few mods and a chip either.it wont.
if your looking for "fun" id go with a 460 gas engine.
if you want the idi in peak performance,do as mentioned above and dont forget proper maintenance;
keep the ip and injectors fresh (every 100k miles max)
have the engine timed (every 30-50k miles max)
check and replace the air/fuel filters and oil changes
open up that exhaust and turbo/cam etc,and moose pump etc.etc.
in the end you can have over 200 rear wheel hp,but its gunna set ya back a few bucks to get it,but she'll never be pops 7.3l chipped powerstroke without internal mods to handle twice stock boost.
on
The 87 6.9 is the preferred motor for performance building, though late 85, 86 motors are just as good with the addition of 7.3 rockers.
Both the 6.9 and 7.3 need head studs in order to raise the boost levels, there currently is no TRUE stud kits for the 7.3, so ultimately you can boost the 6.9 higher.
Installing a stock 7.3 for performance will gain you little if any.
I believe Hypermax is still supporting the IDI.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
Jason
Jason
Jason
Jason
do you have excessive black smoke when you hit the gas petal? if not, then turning it down wont help. if you make it too lean that can do damage, and having less fuel then you need will cause your motor to stress and you will get worse mileage.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
ats is not supporting idi at the moment. they are missing the 3" turn down that comes off the turbo. they said they can not sell any kits since they do not have that piece. they are expecting to get more in around october. seems like every time i call i get a different month it will be ready.
on
Backing the pump off just makes less power, of course it'll use less fuel, Unless you need to stuff your foot into it deeper to get where you are going.
Fuel mileage is mostly up to the FOOT and the brain that says how hard to push that foot!
-Enjoy
fh : )_~
on
Wrong, You cannot lean a Diesel out ...
-Enjoy
fh : )_~
-Enjoy
fh : )_~
Diesels like this run a variable mixture ratio. At idle its very lean while at full power with a little black smoke showing through the high EGTs, it swings toward the rich side of the scale.
Its not possible to damage a diesel engine by running lean the way gassers can be, since preignition in a diesel isn't possible because fuel isn't present in the chamber until TDC, then the fuel self ignites in a controlled manner according to the injection timing. Running "lean" in a diesel basically means you have extra air flowing through that isn't getting consumed. In a diesel, this actually helps cool the motor and thats why they are so good for heavy pulling all day long.
Lowering the fuel screw will have a slight effect on the timing map, but I'm not sure how much. In my experience, lowering the fuel setting can also make for harder starting although I've heard some say that's not possible. Maybe something was wrong with my pump at the time.
on
