1999 f-150 towing
Old 06-14-2010, 06:41 PM
cali201's Avatar
cali201
cali201 is offline
1999 f-150 towing
Question. I have a '99 F-150 stepside, 5.4 with 3.55 gears and towing package (at least listed on the window sticker) and my truck only has 88,000 miles on it from new. Auto tranny also. I have been towing my classic car (3100 lbs) on my car trailer (2,000lbs) with no problem. I was thinking of getting an enclosed trailer which is 3200 lbs. Some of my friends say that is too much for my F-150 and I need to step up to somthing bigger. I do live in the mountains in Georgia and have some steep hills to get to my house, but only a short drive, not extended periods of steep hills. Can my F150 tow a total of 6300 lbs ok? The manual says it is good for 8,000 lbs. An enclosed tailer would have more wind drag then my current open car trailer but I will get a v-nosed enclosed trailer if I can do it with my current truck. Thanks for any help.
Old 06-14-2010, 07:41 PM
TheTinian's Avatar
TheTinian
TheTinian is offline
I pulled about 12k with mine. About pushed to the limit, but you should have no problems towing 6300k.
Old 06-15-2010, 12:07 AM
jgeese's Avatar
jgeese
jgeese is offline
Have a 2002 F-150 pulling our 26' boat weighing 6300# dry not including the tandem axle trailer. Pull it over the mountains a couple times a year including camping gear. Should be do-able...
Old 06-15-2010, 12:36 AM
cogden's Avatar
cogden
cogden is offline
You will be fine.
Old 06-15-2010, 10:09 AM
ZTG's Avatar
ZTG
ZTG is offline
i have a 99 f-150 4.6l and i haul bobcats with mine . she knows its there but i have never had a problem. 6300lbs should be no problem.
Old 06-15-2010, 11:56 AM
Big Greenie's Avatar
Big Greenie
Big Greenie is offline
Temporarily Deactivated
I think it is pushing the limits of the truck. I also think it will do the work, just do it very slowly. With a load leveling hitch, at least D rated tires filled to 65 psi, and trailer brakes in good working condition, it will do it. I bet it would do it for a long time with no problems either. Expect 8-10 mpg though.
I just prefer the turbo diesel trucks for hauling. It is a night and day difference. Lots more power, better suspension and frame, better fuel economy by 5-10 mpg.
Old 06-15-2010, 12:33 PM
jgeese's Avatar
jgeese
jgeese is offline
Tire ratings have little to do with pulling a trailer vs. hauling a load in your truck. Tongue weight should be about 10% of combined trailer weight when towing.
Old 06-15-2010, 01:44 PM
ZTG's Avatar
ZTG
ZTG is offline
diesel is totally the way to go but if all you have is your 150 then you have to do what you have to do and she will be fine!!!!!
Old 06-15-2010, 04:43 PM
TheTinian's Avatar
TheTinian
x2. After a couple trips towing my old truck around I bought a 7.3 SD.
Vole
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
31
04-17-2016 03:51 AM
MC5C
1999 to 2016 Super Duty
07-13-2014 07:15 PM
DrunkTruck
13
12-04-2013 09:39 PM
cali201
1997 - 2003 F150
03-29-2011 08:36 AM
saleen065
22
10-12-2009 12:46 PM
Quick Reply: 1999 f-150 towing
