2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Rear window on EL
Old 06-08-2010, 08:45 AM
unreal72's Avatar
unreal72
unreal72 is offline
Rear window on EL
The windows have what look to be hinges/clasps located at very back of rear side window but don't open. Is there something I am missing? are they supposed to crack open or not?
Old 06-08-2010, 09:21 AM
clearnetedm's Avatar
clearnetedm
clearnetedm is offline
Might be the powered quarter vents. If you have the moon roof look for the switch there to open them. That's where mine is anyways.
Old 06-08-2010, 09:31 AM
unreal72's Avatar
unreal72
unreal72 is offline
thanks...i think you might be right...i didnt look up there.
Old 06-08-2010, 11:48 AM
berry1234's Avatar
berry1234
berry1234 is offline
The powered rear quarter window glass will not have any exterior hardware visible and a power switch next to the front map light buttons.
Old 06-08-2010, 08:08 PM
ford-speed's Avatar
ford-speed
ford-speed is offline
your motor is bad. try pushing the switch while you smack the door with your hand and see if you can jar the brushes loose
Old 06-09-2010, 08:46 AM
unreal72's Avatar
unreal72
unreal72 is offline
I found the button for rear windows....I guess I didn't look hard enough.( face turns red) Thanks for input!
kconrad
06-13-2013 10:45 AM
trshman
1997-2006 Expedition & Navigator
11-07-2012 06:56 PM
Elmo154
05-15-2011 10:33 PM
93F250
08-29-2006 10:07 AM
Quick Reply: Rear window on EL
