Help on Why my 1964 V8 F-100 keeps bending 4 push rods
finding out they were bent was easy. it would be running fine and then one or two of the valves would stick and bend those pushrods and a distinct ticking noise would start coming from motor. pull the valve cover and free up the valves and replace pushrods. few days later repeat.
I wanted to rehash this thread to say Thanks for the help on this one. It hasn't bent any pushrods in about 2 years. I let the truck sit for about 8 months and during this time I rebuilt the carb. The carb was extremely dirty! It had gunk you could scrape up with your finger like mud.
I also changed the fuel filter which was horrible as if it had been dipped in mud. It was so dirty, that leads me to believe this was the cause. Also after getting the truck going after sitting and after the rebuild it has a loud lifter tap. Could this have been caused by a combination of bad gas and sitting for so long?
I have never delt with a lifter tap, how should I go about addressing it?
Thanks
Thanks
Ki-Adi-Mundi
16
01-03-2015 09:36 AM
1964 f100
01-22-2013 07:00 PM
1974F2504X4
12-13-2004 04:55 PM
bhabben
05-10-2002 10:46 AM
