Power steering upgrade
Old 06-08-2010, 07:55 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
I'm sure this has been discussed before, but here it is again. My 94 had the normal noisy pump, and when using 4 wheel drive, it would spit fluid out. So I ordered a Cardone(sp?) #20-6244. I also grabbed a pressure line off a 85 pickup. The pump was all bolt on, the belt even fits still. Just had to bend part of the hard line on the pressure lin. Now there is no pump wine, and it turns even easier than before. I also have this same pump on my 78. Has worked great on that, so figured I'd use one on my 94 too.
Old 06-08-2010, 11:18 AM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
Are you aware of a version of those pumps that has two return lines? You now, for running hydroboost
Old 06-08-2010, 11:23 AM
hav24wheel's Avatar
hav24wheel
No, I don't know of one, but, you could nab a "can" off a Chevy pump that has two return lines and use that on this pump. Or I'm sure you could very easily add a return line to this one.
Old 06-08-2010, 11:30 AM
Hitokori's Avatar
Hitokori
Hitokori is offline
or u could T into the return for the power steering return for the booster
Old 06-08-2010, 11:31 AM
darthice's Avatar
darthice
darthice is offline
let me ask what exactly does hydroboost do for your power steering system?
Old 06-08-2010, 11:33 AM
Hitokori's Avatar
Hitokori
Hitokori is offline
hydra-boost is a hydraulic brake booster that gets its boosting capabilities from the powers steering pump
hav24wheel's Avatar
hav24wheel
Hydroboost uses your powersteering for pressure for a brake booster instead of a vac can
Old 06-08-2010, 11:36 AM
darthice's Avatar
darthice
darthice is offline
so is it better or worse than the vac can boost?
Old 06-08-2010, 11:38 AM
hav24wheel's Avatar
hav24wheel
Hydro boost is Better. Works great. Can be spendy to swap over though.
Hitokori's Avatar
Hitokori
Hitokori is offline
well... it has its highs and lows... if u have a p/s pump leak and fluid runs low it sucks brakes get hard and the pump screams every time u brake.... but it is heavier duty than vacuum boosted
Old 06-08-2010, 11:41 AM
darthice's Avatar
darthice
darthice is offline
hummmm has anyone ever added this to their ford trucks? It sounds like something i would be interested in doing if it is possible
Old 06-08-2010, 11:43 AM
hav24wheel's Avatar
hav24wheel
Yep, people have done it. A variety of diesel pickups have it on them.
Old 06-08-2010, 02:43 PM
LCAM-01XA's Avatar
LCAM-01XA
That's what I was thinking, I wanna run an extra-capacity tank anyways so the Chev setup will be a good way to go about it.
You actually don't wanna do that, as if you steer and brake fast at the same time you can dead-head the steering or the brakes (depending on how you have the T-ee plumbed in) and kill its power assist - it's not common, but it happens, I've done it with my old Chev that I hydroboosted without using the expansion can mentioned by hav24wheel.
It's been done quite a few times, you can use factory Ford parts from/for an F-Superduty truck, or you can even adapt hydroboost units from other makes (like for instance how I have one from a 3/4-ton Suburban). Do a search, you'll find tons of information on the subject.
Old 06-08-2010, 03:19 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
i have a power steering pump off the race car my bro had last year... remote reservoir too...
:P i wonder how much work it would be to mount it up.... ill have to look saturday
Old 06-08-2010, 04:03 PM
LCAM-01XA's Avatar
LCAM-01XA
Well depends on what pump (or actually reservoir) you have now - I run hydro-specific reservoir so I have a return port on top of it before the fill neck, for me adding the extra tank would be as simple as running a line off that port to the new tank and also plugging the vent hole in the factory cap so fluid don't overflow from there. In your case with a factory single-return port I'd redo return line from the steering box entirely and run it to the add-on tank first, and then run another line from the tank down to the factory return port on the bottom of the PS pump. Really the whole idea of the extra tank is to circulate more fluid through the system which allows for more cooling, in case of the hydroboost you already have the extra circuit through the brake booster so you can have that run through the add-on tank and leave the steering lines as is, but with just a steering circuit you wanna move the line to the add-on tank.
Quick Reply: Power steering upgrade
