fuel leak!
If you catch the fuel line early enough, you can protect it with a short piece of 5/16" fuel line and keep it from rubbing through.
Here is what my fuel line looked like a couple of years ago:
The bracket is located at the front of the turbo pedestal mount, bolted to the cylinder head:
The compression sleeves at the ends of the hard line are not reusable as they will be cracked and come out in pieces when you remove the fuel line but we have you covered on those too.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzleguzzle's Mods & Maintenance website
LIGOOMBA
11-10-2008 08:39 PM
