6volt gauges
There are several types of voltage reducers available for handling this. Google "RUNTZ voltage reducer" for one of the most common ones. They will only handle a maximum of two guages, so you'd need a few. A cheap alternative is a factory Ford reducer. Ford continued using 6V guages up into the 70's. You can find a little rectangular tin can instrument voltage regulator attached to the back of the instrument cluster in 12V vehicles of that era. They're cheap, easy to find, and work great for 12V conversions.
A couple of key points. You can choose to replace your 6 volt gauges with 12 volt (sold at LMC) - they come with new 12 vot sending units - for about $300-$400.
If you use the 6 volt gauges with voltage reducers, you MUST use the original 6 volt sending units for each gauge as well.
You can convert your electrick oil and temp to mechanical. It's a fairly easy surgery, but your electric gas gauge you are kind of stuck with. That is how I handled my 6 volt gauges on my 51.
I have a gallery with pictures and instructions on how to install the mechanical gauges in your present housings.
Here is a thread on using the voltage reducers on the gauges. Disreguard the goegraphical differences between the 51 inst. panel and the 55 set up, electrically , the procedure and the flow path/wire hook ups are the same. I recommend you use one reducer per gauge.
https://www.ford-trucks.com/forums/8...12-volt-2.html
I'll second this, cheap, easy and works.
Hey cookieman. I'm not sure which way your wanting to go but I ave the set that was in my 55, they worked fine and they were already 12 volt. Ill get a pic of them for you if you want and as for price i'm sure we can figure something out or possably make a trade (I'm pretty cheap and easy myself)...lol
Here's the link to the H.A.M.B Post on the voltage reducer. I guess it's a matter of your time VS the extra $45 to buy off the shelf.
How to Build a Voltage Regulator for $3 - THE H.A.M.B.
Holehawgg
06-29-2014 10:24 PM
