hyper lube coolant additive
Old 05-27-2010, 07:46 AM
hotrod351's Avatar
hotrod351
hotrod351 is offline
any one use this product. also checker has a sale on seafoam, what about it.
Old 05-27-2010, 10:04 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
Do you need a coolant additive? If you're overheating or running hot all the time, there is a problem you need to address, not try and cover it up with additives.
Old 05-27-2010, 10:38 AM
hotrod351's Avatar
hotrod351
why did i know that some one was going to come back with that answer. thats not what i asked, or should i say said. never said i had a heating problem, dont. just asked, well its posted right there what i asked. oh and by the way, i live here in arizona where temps get to 125 degrees in the summer and i run my ac.
Old 05-27-2010, 10:52 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
I asked if you needed it. You could have simply said, I live in a very hot environment and could use a little help to cool it off a bit more. Yes I have used a surface tension reducer in my motorcycles because you can't run coolant on the track. It works.
Old 05-27-2010, 11:29 AM
hotrod351's Avatar
hotrod351
you could of just not answered the question, seeing as you dont know anything about the product. it seems to me to be a very simple question, any one use it and did it work, thats all, yes, no. not = if you have a heating problem you should mask it up with a additive. you assumed.
Old 05-27-2010, 12:24 PM
Prozon's Avatar
Prozon
Prozon is offline
Calm down. It was a simple question.
I've seen them work before. What brand are you planning on using?
Old 05-27-2010, 01:25 PM
zxwut?'s Avatar
zxwut?
zxwut? is offline
You're assuming I don't know anything about the product. It's a surface tension reducer, same as water wetter. It will help with heat transfer. It prevents air pockets from forming on the walls of the coolant passages.
Old 05-27-2010, 04:36 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
i havent used the exact product u are talking about but i have used water wetter and it worked wonders for the race car
Old 05-27-2010, 05:05 PM
hotrod351's Avatar
hotrod351
i saw a report about the comparisons between it and water wetter, plus a few others. the only thing i ever read about water wetter that was neg. is that you can end up with leaks in your system. might just give it a try.
Old 05-27-2010, 05:09 PM
zxwut?'s Avatar
zxwut?
zxwut? is offline
I've never seen a leak that was due to water wetter. In those cases, there were probably other issues that directly contributed to it.
Old 05-27-2010, 07:32 PM
hotrod351's Avatar
hotrod351
that could be.
Old 05-29-2010, 08:45 AM
hotrod351's Avatar
hotrod351
well it works. lowered temp. 10 degrees at cruising and idle with ac on and 100 degrees outside.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: hyper lube coolant additive
