Timing belt broke... is a 2.5 an interference motor?
Old 05-23-2010, 06:26 PM
cjsteak's Avatar
cjsteak
cjsteak is offline
I'm working on my neighbor's kid's 1998 Ranger with 2.5/Automatic.
The truck has 179k on it, with what I'm sure is/was the original timing belt. I installed a new timing belt and the engine had a nasty clatter when started, but ran really smooth. We shut it off after 5 seconds.
I removed the cylinder head expecting to see damage to the valves or pistons and couldn't find any contact marks.
If the valves didn't hit the pistons, then why the clatter? When a timing belt goes on a 2.5, do the pistons not hit the valves?
Maybe something is bent so slightly it's not visible to the eye...
Any tips or advice is much appreciated.
Thanks,
-Chris
Old 05-23-2010, 07:16 PM
kotzy's Avatar
kotzy
kotzy is offline
Chances are the lash adjusters bled down while you turned the cam while putting on the new belt. Had you run it a bit oil pressure would have filled them and the clatter would have left. kotzy
Old 05-23-2010, 07:37 PM
cjsteak's Avatar
cjsteak
cjsteak is offline
BAH!
So it's NOT an interference motor... dang it. I just went through all this extra work to pull the head.
Thanks for the advice. I guess I'll put the old head back on it.
Quick question for ya... I noticed a diamond shaped timing mark on the cam sprocket, and a diamond for the oil pump sprocket. I'm supposed to align the sprockets with the matching shape correct?
Old 05-24-2010, 08:30 AM
kotzy's Avatar
kotzy
kotzy is offline
I'm not sure if they changed anything on the 2.5 as too marks perhaps someone else can answer your question. kotzy
Old 05-24-2010, 12:24 PM
powersmoked's Avatar
powersmoked
powersmoked is offline
Originally Posted by cjsteak
BAH!
THE 2.5 IS A NON-INTERFERANCE ENGINE. I agree with Kotzy IT WAS PORABLY THE OIL PRESSURE. Someone was just posting last week that he had a clicking after the timing belt replacement. He had not primed the oil pump and the noise went away after a few minutes.. dID YOU CONSIDER HAVING THE HEAD CLEANED UP AND INSPECTED WHILE IT IS OFF
You sound like you know what you are doing but you must remember.....DIAGNOSE AND THEN REPLACE........
Old 05-24-2010, 12:42 PM
powersmoked
I have never changed a belt on one of these, however I have read a lot of threads on them. from what I understand you line the key strainght up on the crank. Then you line up the marks on the cam and the oil pump with there matching marks.
*I am not sure how you prime the oil pump I wonder if you could pull the fuel pump relay and crank it for a while?
1980 Bullnose
07-13-2014 01:44 PM
dkoenig
1997-2006 Expedition & Navigator
16
04-28-2011 08:54 PM
fored
10-28-2007 07:59 PM
SteveH-CO
1999 to 2016 Super Duty
19
01-01-2006 01:09 PM
ArcticRanger
4 Cylinder Engines
04-09-2004 10:12 PM
Quick Reply: Timing belt broke... is a 2.5 an interference motor?
