After market prop valve
I have used the Wilewood valve on other projects. As I used it the front brakes were effectively "T'ed" to the MC and the rears ran through the prop valve. To set the prop valve, I used an empty road on a damp day. I reduced rear pressure until the fronts locked up first (barely) on hard stop. Rear brakes locking up first is not desired and causes control problems. With a PU and variable loading in the rear you have to decide how to test... empty or some load? That's the nature of PU's.
kylecoyote
09-17-2014 09:21 PM
Handegard
09-30-2011 07:09 AM
F-250 restorer
09-22-2010 11:19 PM
llcvt15
09-22-2010 04:37 PM
NC2X4
27
09-15-2010 10:54 PM
