Real retarded question...
I do, and several others here also run B100. Being that yours is a '94 however, you may need to see if your fuel system lines, seals, etc. are compatible. Not sure when exactly, but in the mid '90's, Ford/International went to viton fuel components. Our 7.3's run great on bio.
Good to know! While completing this swap, everything in the truck was swapped out with the 97 parts, fuel tanks, fuel lines, the whole mess!
Doing the swap, really in order to make sure it worked soundly and doesnt have any issues, I had to essentially build a 97 model! LOL!
I have done a good amount of research on making bio-diesel, and the more I learn, the more I am strongly swayed to starting this process.. I am really amazed with this stuff!
Here's a link to a good place to get started:
make-biodiesel.org
And for the latest advancements, plenty of great information and tons of reading, this forum has many of the leaders in homebrewed biodiesel:
Forums - Powered by Social Strata
You may have already caught on to these sites, but just in case you hadn't yet, I thought these would help. Good luck.
make-biodiesel.org
Thank ya!!
The first link I havent seen, so it will be serious reading time tonight! The second one I did come across, and very informative.. It actually gave me lots to start with and develop from there! Great technical data and specifics!
At first when I started considering this, I was very reluctant and worried about the work and technical aspects of getting into it.. The more I read, the more I learn, the less frightening this looks! One of those sites talked about "running tests on a small scale first".. I like that idea.. Then I can actually see the process in its working state, and get a much better idea!
I am really planning to be running B-100 only from here on out once I get up and going!
