what pump is this?
05-15-2010, 06:45 PM
what pump is this?
0862731A << number on pump
is there anyway to tell from this number on it
thanks john
05-15-2010, 07:04 PM
on
05-15-2010, 07:46 PM
oh yeah lol sorry.. its a high pressure oil pump from a motor i got wondering if its a 15 or 17?
05-16-2010, 05:08 PM
anybody ??how could i tell with out taking it apart?
thanks john
05-16-2010, 06:56 PM
hm, I am trying to remember but one them has a hump on the back of the pump, but I can not remember which one, what kind of fittings does it have? the SD fittings are different than the OBS ones, I would compare it to the one that is in your truck, if the housing looks different then it is probably a 17, any other numbers on it?
05-16-2010, 09:35 PM
05-16-2010, 09:54 PM
If you got it on a motor the look at the fittings. If they are quick loc then 17 degree.
If they are compression then it is a 15.
There are other ways to tell but you will have to remove the rear cover.
05-17-2010, 09:31 AM
Quote:
Originally Posted by
Neal 97 250
Actually this is not 100% accurate either. If it is an early '99 then it is a 15° pump with quick loc fittings.
The best way to be for sure is to remove the rear cover and look at the bearings.
Red454sedgwick
06-23-2016 10:31 AM
P38fighter
08-06-2015 11:37 AM
robjs111
1978 - 1996 Big Bronco
05-06-2013 11:43 PM
84-250
09-25-2008 01:22 PM
fordsrgrt
04-30-2006 12:39 PM
