Who makes this posi unit??
Old 05-12-2010, 02:48 PM
lizardman1's Avatar
lizardman1
lizardman1 is offline
This was described to me as a Eaton TrueTrack. It is not that at all. Is this unit as good??
Old 05-12-2010, 06:29 PM
ReAX's Avatar
ReAX
ReAX is offline
That looks more like a spool than a diff, except for the gears. Maybe some kind of one legger? I found this, Ford 9 Inch Rear Truetrac Posi LSD Limited Slip 28 Spline [TT 912A587] - $499.00 : JTs Parts & Accessories, Justdifferentials.com The picture looks close and calls it a true trac.
Then there is this page Ford 9-inch Axle - Off-Road Magazine The true trac looks right again. This is all assuming you are working with a 9".
Old 05-12-2010, 08:09 PM
lizardman1's Avatar
lizardman1
Just found out it is an Eaton True Track, fits Ford 9" and does not look anything like the generic pics online. Shocking!! As for the manufacturers shame on them, there needs to be an accurate pictoral representation as per aplication just my 2C worth. Thanks for the response.
Old 05-12-2010, 08:20 PM
ReAX's Avatar
ReAX
ReAX is offline
the bigger case design probably is the same for the C-clip axles like the 8.8 and Corporates. So the picture probably covers most fords and all chevy's, who knows about dodge. Just the 9" is different because the axles get bolted to the flange.
Old 05-13-2010, 08:56 AM
lizardman1's Avatar
lizardman1
I found out it is a True Track. it looked different from the others I have seen because the others were for other applications. Thanks for the help.
eco
04-03-2007 05:34 AM
300-6 AUTO TECH
03-01-2007 06:15 PM
Scopie
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
01-24-2005 10:21 PM
whaynes
07-30-2002 12:57 AM
Derek S
1999 to 2016 Super Duty
12-26-1999 06:53 PM
Quick Reply: Who makes this posi unit??
