Firing Order and position on distributor for cylinders
Hey guys. i need to run the wires on my 5.0L now and all the markings i made on the wires are missing now so i have no clue which wire goes where. Is the firing order i need to use the HO order- 1-3-7-2-6-5-4-8??? or should i still be using the stock order that the truck engine originally had??? i know i had this info saved on my computer, but it got messed up and that stuff was lost.. thanks guys!!!
ok cool. thats what i thought. one more question. is there a line or something on the distributor to show where the #1 plug wire should be??? Like i said in the original post, mine isn't marked anymore and i didn't think to mark a line on the cap with paint or anything to show where number 1 was at. thanks guys.
I think you are going to have to go back to first principles.
You will need to get No1 piston at Top Dead Center ON THE COMPRESSION STROKE. IF you take NO1 spark plug out and get a helper to crank the engine while you put your finger over the plug hole you will feel the compressed air blow past your finger as No1 comes up on the compression stroke. Stop cranking then and use the timing mark on the crankshaft pulley to get TDC. The rotor will now be pointing at No1 position.
Good luck.
Good luck.
frankhenderson
09-05-2014 04:49 AM
reamer
23
03-22-2014 12:38 PM
99cadillacman
12-02-2003 12:20 AM
