Goodyear Duratrac pics and review!!
Just by looking at the tire I would suspect that it is prone to noticeable squirm or tire roll. From a pure on road stability and squirm/sway control point of view, tires with solid or continuous ribs are best.
The more nobbies and the smaller they are increases squirm. Softer rubber and thread depth contributes even more to squirm and so does the actual tire size.
Duratracs - They have lots of nobbies and some that are pretty small. Nobbies have siping cut into them making them have more surface for increased traction.
Rubber is probably softer than a mud tire because it is targeted for winter traction. Add all those factors up and it could equal a noticeable amount of squirm and possibly an undesireable towing tire.
reading this made alot of sense. good thing i dont tow alot, but when I do, i'll be sure to let you guys know how it handles. reps sent.
well, one thing i figured out today is i can still go full lock. it's very unpleasant, but nonetheless. i wasnt sure before. but i think if i would have went with something that didnt have such big lugs, it wouldnt be so violent when they do rub the leafs.
went and washed the truck today. went to the same automatic i always do. last time i went there with my old tires, i really broke them loose trying to get over the stop hump. the duratracs just crawled over it with no prob. i'm anxious to see how they'll do in a heavy downpour.
also, pullin out the nieghborhood today, i found out the good ole' 7.3 has enough power to really turn them over!!
I know a few people with the Goodyears they seem to be okay they are getting a year out of them about 30,000kms (19,000 miles) which is pretty d*mn good for tires on a diesel pick up. My brother has them on a Dodge 3/4 ton Cummins he is getting decent life out of them they don't howl I think my brother will get 30,000kms out of his tires.
Here is how I fixed my leaf spring rub:
1. turn the wheels all the way side to side measuring the gap at the bump stops. (might have to get someone to do this for you while you measure)
2. tack weld something to the bumpstops slightly thicker than the measured gap on each side. (I used a 1/4 inch steel nut)
3. grind it down to the correct angle to align with the stock geometry.
4. Wwallah! No more rub.
Problem is, max PSI will wear out the middle and still not realy help the roll problem because of how the sidewalls are pulled in. They are softer even with the right wheel because they are a taller tire. I went through this when I went up to 305/70r16. New wheels made a big difference but still a little narrow for the tire IMO. I was getting a lot of wear and noise because the tire was crowning. The wear has improved, and the handling too but I would rather see a slightly wider wheel on a 305 or 315 tire, maybe 8.5 to 10 inch. Problem is then, the wheel has to stick out because of the knuckle.
I'm running 315/75/16 Toyo ATs on a 16x8" rim right now (back to the set that came on my truck when I bought it). Seems stable, though definitely a softer ride than the E Rated 35x12.50 on 18x10s I had before. The Toyo's are only D rated, 50 psi, so they are soft, but not squirmy.
Goodyear recommends rims 8-10" wide for the 315/75/16 DuraTrac, so I'd shoot for 9" wide if possible.
#28
#30
