I want to level my 2010 F350 SD. What level kit do you recommend (maybe 2")? I want something that is not too difficult for the back yard mechanic to install.
I have a ready lift 2" kit on my truck and it is fantastic. It costs about $150.00 and is very easy to install. Since you and I both have 350's you only need the front coil spacer, which mounts on top of your springs. Easy install that any shadetree mechanic can tackle with 3-4 hours work. When complete I was able to fit 325/65/20 Nitto tires on my stock 20's with no rubbing at all. The only thing you need to do is get it aligned after the install.
