New! Air cooled oil cooler for 6.0
Just read the installation guide to oil cooler this is a big job, have to pull old oil cooler, evavcuate AC system to remove and reroute hoses, remove front bumper install cooler, because of hot air being dumper in front of Condenser they recommend installing an upgrade orfice kit for Ford AC. Would this orfice kit improve the stock AC?
Here are the issues as I see it.
A) pressure
Does it materially delay the onset of "full pressure" for the engine?
It depends - where is the oil tap?
If oil is tapped after it comes off from the pump from sump, then yes.
It does add a delay (not counting the "priming" delay from the oil change).
A lot of times, a check valve will prevent oil from draining out of the cooler in between oil changes, so the real delay is minimal.
B) Normally an air cooled oil cooler require a thermal bypass valve, so the oil is not overcooled in cold climates.
Does this one have one?
C) Then there is the reliability issue of running more oil hoses, more radiator space that is additional parts to fail.. to be offset against sand clogging oil coolers / EGR cooler failures.
Put the whole thing together --- and not considering price ---- I am going to say, I would go for it under the following circumstances
A) a bona fide need for higher cooling capacity because of heavy loads --- you can always add a bigger air cooler.
An air cooler can have more cooler capacity by making it bigger, or getting more air across it (aux. fan, etc.) but air cooling, all things considered, is less efficient than liquid cooling with coolant.
B) the key to reliability is to keep oil warmed (at slightly below normal underhood temperature) so it is not too hot or too cold.
That is where lubricants do best --- not when it is very cold, and not when it is very hot.
A side benefit of the liquid oil cooler is that it warmed the oil as well as cooled it.
This rig will take that away --- the cooler becomes strictly a cooler.
C) One issue with air coolers is in extreme cold and with dino oil, it is conceivable for the cooler to be effectively jammed / frozen shut by molasses like oil --- something to consider in very cold climates.
In those applications, normally, there is a "bypass" that ensures oil flows --- in some cases, aux heating to ensure that oil in the cooler flows properly.
So if they gave me the kit for free.. I would test it.
A) pressure
