Oil cooler location
Old Jul 12, 2011 | 05:51 PM
LKCKR's Avatar
LKCKR
Oil cooler location
A friend of mine is going through diesel training and told me the probable cause for my EGR valve and cooler clogging could be my oil cooler being clogged and my turbo having carbon build up. Is this possible and if so where is my oil cooler located and what is the best way to clean it and my turbo? Any help would be cool.
Thanks Tom
04 F350 6.0
129000 miles
no tuner or chip
4 inch turbo back
AFR dry stage 2 intake
Old Jul 12, 2011 | 07:27 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
did you look through the "READ FIRST" folder up top? LOTS of good info there.....
I think this is where you wanna look for now. Powerstroke 6.0L Technical Intro Manual
Old Jul 12, 2011 | 07:36 PM
69cj's Avatar
69cj
Many people blame the egr/egr cooler. In reality the oil cooler fails, plugs up, and causes the egr cooler to over heat and fail. They replace the problem and eliminate the messenger. Bad choice in my op.
Old Jul 12, 2011 | 10:33 PM
LKCKR's Avatar
LKCKR
Wow that is good info to have, so when you say they replace the problem are you talking about the EGR and cooler or the oil cooler?
Old Jul 13, 2011 | 03:18 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
They, Ford< used to only fix the EGR Cooler, now they replace both the EGR cooler and the oil cooler. The oil cooler is the cause, the EGR cooler is the effect.
Old Jul 13, 2011 | 08:55 AM
olfordsnstone's Avatar
olfordsnstone
Hmmm, I hesitate to post this hypothesis...
Is it possible that the reason the oil cooler is clogging might be due to the exposure of exhaust passing through an exhaust cooler, i.e. the egr cooler, which could be super heating the coolant and damaging the coolant? It has been suggested that this exposure may be contributing to the drop out of solids and goo within the coolant. If this is accurate, then could it be possible that the EGR cooler is causing the oil cooler to clog, which causes the EGR cooler to fail?
Old Jul 13, 2011 | 02:14 PM
eyeman05's Avatar
eyeman05
Chicken or Egg. This is fun. Go fella's. This is anything but boring to we 6.0L fans. Do we watch the ECT vs EOT delta to tell us when to replace the oil cooler or.........
Old Jul 13, 2011 | 03:16 PM
69cj's Avatar
69cj
Some have also speculated that the clogging was from silicate drop out in the Ford Premium Gold and have changed coolants. Yet some have gone a 100,000 miles plus on the gold with no problems. Some have also found casting sand in the cooling system. Myself being one of the later. I have installed a coolant filter as a pre-emptive measure. Some have not and had no problems. I for one believe in leaving the system as designed and do the pre-emptive items to include maintenance that is more stringent than Ford requires. I like to think that a direct result of this is the reason that my truck has never left me stranded anywhere.
Old Jul 13, 2011 | 03:24 PM
eyeman05's Avatar
eyeman05
How'd you find the sand?
Old Jul 13, 2011 | 03:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
All ya gotta do is look into the bottom of the coolant jug!
Old Jul 13, 2011 | 05:34 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Found mine in the bottomof this bucket when I drained a couple of gallons from the radiator:
When I was doing my coolant filter install:
It came out of the bottom of the radiator I guess. Drained about 2 1/2 gallons of coolant for the install. Sorta looked like metal shavings but a magnet wouldn't pick it up so I'm saying it's sand.
Old Jul 14, 2011 | 08:49 AM
eyeman05's Avatar
eyeman05
Have you been plugging filters since the install? If so, how do you know when it plugs? To wait until the ECT goes up seems like it would be too late - damage already done approach.
Old Jul 14, 2011 | 09:03 AM
Rusty Axlerod
No plugging yet (as far as I can tell) pulling filter this weekend. Pulled a camper the 4th weekend first time with filter and SGII. Temps were high 225/235 pulling hills. Going to clean outside of radiator, intercooler, and condenser while I'm in there. Temps and delta is ok unloaded.
Old Jul 14, 2011 | 09:17 AM
nylyon's Avatar
nylyon
In the spirit of speculation and an attempt to help dispel fact from fiction, the "casting" sand which everyone is finding. How do you know it's casting sand, was it tested? Is this casting sand really silicate fallout and not casting sand at all? Here's a favorite antifreeze article of mine with a great picture of silicate fallout which I could see being mistaken for casting sand. Again just in the spirit of speculation..... :-)
Click here for slicate fallout picture
Last edited by nylyon; Jul 14, 2011 at 09:20 AM. Reason: Picture too big, mae a clicky
Old Jul 14, 2011 | 10:26 AM
Rusty Axlerod
Does look like sand. Thanks for the pic and article links.
