49 5 Speed Overdrive
Old 05-01-2010, 01:09 PM
C-700's Avatar
C-700
C-700 is offline
Anyone interested in a good one. Figured I would ask before I shop it around. Should fit F3, F4, F5, F6, F7, & F8 for a lot of different years.
<!-- / message -->
<!-- controls -->
Old 05-01-2010, 01:18 PM
fifty-two_f1's Avatar
fifty-two_f1
fifty-two_f1 is offline
Can you post a picture and where are you located? Is it syncro?
Old 05-01-2010, 03:33 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,059 Likes on 804 Posts
As far as I know Ford didn't have a five speed in '48-52, just the three and four speeds.
Old 05-01-2010, 10:36 PM
C-700's Avatar
C-700
C-700 is offline
If interested PM me. Ford did have a 5sp in 49 and I can open it up and get pictures.
Old 05-01-2010, 11:06 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
Lincoln 337cid
Old 05-02-2010, 09:09 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
I apologize, I wasn't thinking about the larger F-7 and F-8 trucks.
If it's for the F-7 and F-8 with the 337 I would doubt it would fit the smaller flathead and if it did it would be a low geared heavy beast. From the drawings it looks like they have different mounting surfaces. I'm sure it would take a lot of modifications to make it fit the frame without any benefit but I could be wrong.
Old 05-02-2010, 09:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
That's a big, big tranny...
Great minds... eh, Bob?
Old 05-02-2010, 09:16 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Ross, I beat you to it!!
Old 05-02-2010, 09:23 AM
havi's Avatar
havi
havi is offline
Thanks for the diagrams.
Old 05-02-2010, 09:34 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Nope, at least not identical. In 53 they came out with a new model.
Old 05-02-2010, 10:56 AM
fifty-two_f1
Will this five speed fit a 54 f600 with a 239 yblock? are the bell housings the same?
Old 05-02-2010, 02:50 PM
mtflat's Avatar
mtflat
mtflat is offline
No: F1-F6 used the same trans/ bell housing, etc. They used different stanchions under the transmission to adjust for the larger frames, but the main parts are the same.
F7 and F8 used the bigger flat V8 (337 cid) and the 5 spd trans.
The 5OD was standard on the F7 and optional on the F8.
The plain 5 spd was std on the F8 and optional on the F7.
IF I remember what the shop manual and operator's manual says.
Old 05-02-2010, 03:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
But if he used the bell from his F-600 Y-block, would the 5OD bolt up to that, and be the right length to flywheel?
BTW, the upper of Bob's pictures is the 5OD, and I don't see any synchros...?
Old 05-02-2010, 07:30 PM
fifty-two_f1
I dont know if you guys are familiar with the 60s internationals, but they used 3 and 4 speed trans that should bolt right up to a ford. I have a 63 c1300 with a straight 6 and it has 4.88s and is SLOW. It has a three speed and a five speed with overdrive would be sweet for that truck. and if it did not bolt up as planned then it should go in my 54.
mtflat's Avatar
mtflat
mtflat is offline
Oh shoot, I don't know - I didn't see he was talking about a '54 and Y block - must have only seen his user name. Talking before thinking again - sorry.
Quick Reply: 49 5 Speed Overdrive
