mountaineer left front popping
Old 05-01-2010, 11:57 AM
mwkobe's Avatar
mwkobe
mwkobe is offline
2002 MM AWD has a popping in the left front if i turn hard left but its just one pop. when the pop happens you can feel it under the drivers feet. It is also very bindy when turn but im told this is normal.
Thanks wayne
Old 05-01-2010, 01:42 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
ok can someone tell me or show me what the steering stops are supposed to look like? I think something is missing on them because they dont look right and my wife now says it makes it in hard turns both ways I put some grease on the friction points for the steering stops and the noise seem to be gone i will give it a few drive before i say its the problem
thanks wayne
Old 05-01-2010, 09:04 PM
shorod's Avatar
shorod
shorod is offline
I would certainly suggest you get the weight off the front wheels and check the ball joints and tie rod ends for looseness.
-Rod
Old 05-01-2010, 09:12 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
did that but didnt find anyting but i can do it again
wayne
Old 05-02-2010, 02:16 PM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
I would be checking the CV joint..... for the popping
Definitely the BJ and tie rod ends for stiffness.
Old 05-02-2010, 02:46 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
ok i will but its just one quick hard pop that you can feel in your feet
is there any positive way to check your lower control arm bushings because i believe i can see fatigue in my right lower C A which would make sense that it takes more strain when turning left.
thanks wayne
Old 05-03-2010, 06:21 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
ok has anyone had problems with the transfer cases on these i finally had some help and it sounds as if it is coming dead center under truck i know i was way off at first describing it.
thanks wayne
Old 05-03-2010, 07:31 PM
aquanaut20's Avatar
aquanaut20
Originally Posted by mwkobe
ok has anyone had problems with the transfer cases on these i finally had some help and it sounds as if it is coming dead center under truck i know i was way off at first describing it.thanks wayne
Different kettle of fish...... check U joints and slip joints.. you have to drop shafts to check properly...... if not shaft check transmission mount.
Old 05-03-2010, 07:32 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
thanks wayne
My son's Mountaineer had the same problem and it was repaired under the aftermarket extended warrantee. I have it posted back in Dec. or Jan. with at least 1 pic. PM your email address and I'll email a bunch of pics to you.
Old 05-03-2010, 08:35 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
mwkobe, You have mail!
Old 05-03-2010, 09:12 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
No you don't. it got kicked back, trying again.
Old 05-03-2010, 09:18 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
Old 05-03-2010, 09:23 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
as i read my alldata diy manual it says to match mark drive shaft to tcasse flange what good does that doo if you put in a different tcase
thanks wayne
Old 05-03-2010, 09:26 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
thanks wayne
Yes, mark the flanges of the drive shaft and t/case and the dif. to keep it in balance, a crayon or paint stick does a good job
Old 05-03-2010, 09:32 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
not that its fixed yet but this was one of the most frustrating problems for me to find but with people like you it makes things easier. passing on experiences
thanks again
wayne
Quick Reply: mountaineer left front popping
