2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Audio/Video Setup Installed
Old 02-09-2010, 04:18 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Finally got all of my stuff in and installed. Kind of a PITA though.
Parts:overall, pretty happy with the setup. The headunit sounds way better than the stock radio...and the iPod/iPhone functionality is wicked. I also love the Bluetooth function. My only real complaint is that you cannot put custom background screens.
The Headrests are surprisingly of decent quality. They function as DVD Players...or you can use them as a monitor (see pictures below). The only complaint I have is that they are smaller than the OEM units. The zipper cover is nice also. It looks completely factory when zipped up. Might be a good theft deterrant if they don't know it's there
Wiring wise...Ford engineers should be shot with that retarded setup. Ford utilizes a 10 minute battery saver circuit that the radio is tied into. That means they don't have any 12 volt keyed sources as part of the radio harness. It took some creative wiring, but I finally got it done. Not quite happy with it, but I'm working 12 hour shifts until I deploy...so I'll fix it properly when I get back.
btw, I did bypass the e-brake video lock. Extremely simple. If the wire has a 12 volt source (brake off) the video won't play. if the wire is grounded (brake on) the video plays.
I have no intentions of using this capability while driving...but it'll be nice for when the kids are watching and my wife can see what she is doing. before we had to have the 6yr old describe what was happening on the screen and play the guessing game...not an issue now
Here are some pictures.
Headunit:
Headrests:
All Three:
Misc Install Pics:
Old 02-09-2010, 04:30 PM
berry1234's Avatar
berry1234
berry1234 is offline
Looks nice. I assume there is no separate OEM amplifier.
Old 02-09-2010, 07:42 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
not on mine at least. I had the generic 6 disc radio.
I might pick up some better door speakers and a small sub...but I have no area to put the sub. We actually use pretty much the entire rear area all the time.
Old 02-09-2010, 08:40 PM
mtondreo's Avatar
mtondreo
mtondreo is offline
i like those headrest monitors and think that is a pretty good idea that they zip up. Irritated that my 06 expy has the molded in headrests so I am stuck with video in the dash (the kid watches that anyway because she sits in her seat in the middle) and the hanging one in the back. Do the monitors pivot up and down. Also I am surprised that your 08 expy does not have any factory amps and sub. You really should tint those windows some though with the goodies in there (or maybe they don't look tinted in the pix). Congrats - looks nice, Mike.
Old 02-09-2010, 09:01 PM
gddyup's Avatar
gddyup
gddyup is offline
Looks nice Tylus! As far as the sub goes, I have the upgraded 6-disk system in my Limited and the factory 8" sub sits in the D/S rear access panel inside the tailgate. I intend on uopgarding that area to a 10" hopefully this summer if I can get off my lazy *** and get to building a box for it. If you pull that rear corner I'm sure you'll find more than enough room to stash a sub enclosure in there where the factory one would be and keep all the normal rear cargo room you have now.
Old 02-10-2010, 07:32 AM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
So that's what they do with the hole if you don't have 4x4. . . .no 4x2s in my neck of the woods.
Old 02-10-2010, 11:06 AM
berry1234's Avatar
berry1234
All Limitied and Eddie Bauers have the 8" sub in the driver side rear cargo area. There is an amp mounted on the plastic sub enclosure, and I guess the OEM head unit supplies the power for the door speakers. It's pretty loud for a head unit amp.
That is a heck of a price on the headrest monitors. Have you tried them out? Are they ok in the sun?
Old 02-10-2010, 08:17 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
the headrest monitors are actually really nice. I had to bump the contrast and white balance some though.
but seeing as it is sunny every day out here we haven't had any issues yet. the rear windows are tinted enough that the screen still has a nice picture.
but like I said, they are smaller than OEM. so if you actually use your headrests, you will be annoyed. I don't often use mine, so I'll live with it. It is kinda disconcerting the first time you lean back and your head goes backwards another 2-3" farther than you were expecting.
thx for the info on the sub/amp. I'll look and see if I have them sometime. and then figure out how to wire them in. The stocker radio has 3 harnesses on it. 1 runs the jack input, 1 harness is ??? and the biggest harness is the power/speakers/steering wheel controls. I need to break out my DVD manual and see what that unknown harness does.
Old 02-10-2010, 11:22 PM
berry1234's Avatar
berry1234
One is the sub/amp harness. Not there on the xlt and lower trim models.
Old 04-30-2010, 09:14 PM
jayhoskins's Avatar
jayhoskins
jayhoskins is offline
Tylus, how are those headrests holding up? Do you like them. Were they hard to install? I might get them for my 09 Expedition. Is the leater matched well? Still annoying that they are smaller? I find that some people don't like how the stock headrests lean forward so much so it may be better?
Old 05-01-2010, 02:36 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Install was a joke. The back of the leather seats zips...so I unzipped it, ran the wires inside the seat frame, rezipped it, and then tucked them both under the center console.
the dash isn't the easiest thing to work with. but it's really nothing overly hard. just tedious to prevent scratching the surfaces that can be seen
The headrests match about as well as you can expect short of getting your OEM headrests modified. The leather texture looks very similar...my seats have the copper colored piping that the headrests don't have...but it would take a OCD person (myself) to notice that little feature.
The size does still annoy me, but not the wife. I'm 6'3" and she is 5'4" though...so I use them and she can't even touch 'em really. It's her car, so I just live with it. My Mustang has those super leaning headrests and I'm a fan of them. But that is also because I drive hard enough that my head would whiplash if I didn't use them.
The kids use these screens almost daily. I was scared of them initially, but they seem to holding up very well. I would spend the money again.
The headrests also have a pivoting feature. So you can adjust them to fit I think 15 degrees of angle. I set them for a better angle for the kids to see the screen...but I bet I could adjust it to my head better, but then their veiwing angle would be off. I'd rather not listen to them, so their view has priority
Old 05-01-2010, 07:42 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
That's really funny and so true too!
Old 05-01-2010, 09:06 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
any day now and #4 will show up...I can't wait for all that noise when driving around
wonder if earplugs/muffs can be considered a mod?
Old 05-02-2010, 07:54 AM
eddiemoney's Avatar
eddiemoney
Just an illegal mod.. . .
Tylus
1999 to 2016 Super Duty
33
05-01-2013 08:44 PM
Tylus
11-20-2012 10:45 PM
Tylus
104
11-16-2011 04:59 PM
Tylus
10-10-2011 06:45 PM
Tylus
09-09-2011 09:26 AM
Quick Reply: Audio/Video Setup Installed
